MarkBurnell
Message 21 of 26
Re: DSL Issue
If everything is turned on at the same time
Four mobile phones:
2x Lumias
1x one plus one
1x Samsung G
Tablets
2x surface
1xiPad mini
1x Kindle
1x Kindle HD
TVS
2xSmart TV only one uses wifi
Computers
1 Desktop wired
1 Laptop Wifi
MarkBurnell
Message 22 of 26
Re: DSL Issue
4 mobiles:
2 windows lumias
1 one plus one
1 Samsung Moto G
4 tablets
1 iPad mini
2 Surface
1 kindle
1 kindle HD
2 Smart TVs
1 wired
1 WiFi
2 computers
1 Desktop wired
1 laptop WiFi
MarkBurnell
Message 23 of 26
Re: DSL Issue
right, after talking to BT customer services last night, followed by a factory reset (no firmware update this time) and ensuring G.inp is enabled, it looks like we have success. i wouldn't want like to say its cured, only a week or two of use will tell. But we are streaming. I would like to say a massive thank you to everyone that left a comment. It all helped.
Thank you
Mark
TimCurtis
Recognised Expert
Message 24 of 26
Re: DSL Issue
Fingers crossed then.
Let us know how it goes.
Jaseb41
Message 25 of 26
Re: DSL Issue
Hi Mark,Ive had the asus dsl ac68u for about a month now took quite a bit of tweaking to keep the connection stable with the help of asus support and help on other forums managed to keep it connected now for nearly 18 days solid unfortunately I've got heavy interleaving on downstream which has been down to noise on the line a bit of tweaking and 3 firmware updates but im hoping dlm will kick in soon and give me some speed back, have found that these dsl settings are the best and have kept it running this long, regards to wifi i separated the ssids and have had no problems streaming youtube,iplayer etc all fine and signal very good on both 2.4ghz and 5ghz one thing i would say is that asus recommend after a firmware update to do a factory reset by holding in the reset button on the back of the unit for a least 5 seconds which clears out any errors or bugs left by the previous firmware which does actually work, hope this helps and good luck with it !
TimCurtis
Recognised Expert
Message 26 of 26
Re: DSL Issue
The only difference to my set up is that I have DLA enabled.
