papalozarou
Message 1 of 16
DSLchecker returning different cabinet numbers for telephone number and address
Am unfortunately in an area in Kings Cross where I can't get fibre. I've been checking Openreach once a week, for about the last year, where we've been 9 months away from fibre for pretty much all of that time.
Today I checked DSLchecker for both my number and address and have gotten different cabinent numbers, showing different options.
With the telephone number I get cabinet 28 which shows ADSL 2+ and VDSL availability. With my address I get cabinet 19 showing nothing but ADSL 2+. When using the superfast-openreach site I get cabinet 19 for both address and telephone number.
Telephone:
Telephone Number … on Exchange KINGS CROSS is served by Cabinet 28
Address:
Address … is served by Cabinet 19
Which of the above is more accurate?
15 REPLIES 15
Message 2 of 16
Re: DSLchecker returning different cabinet numbers for telephone number and address
telephone number should be most accurate
have you any idea how far you are from exchnage?  what connection speed do you currently get on adsl?  the estimated speeds for adsl2 are widly different
papalozarou
Message 3 of 16
Thanks for the reply imjolly
It's just under half a mile as the crow flies to the exchange.
In terms of speed, I'm getting anywhere between 8-16 down and 0.1-0.4 up – it varies wildly with time of day.
Message 4 of 16
can you post the stats from your router please
have you tried ordering fibre?  have you checked with neighbours to see if they have fibre?
papalozarou
Message 5 of 16
I'm not presently at home (in office), so can't post any stats at the moment.
In terms of trying I've spoken to BT and to Andrews and Arnold. Though in BTs case I've not rung them up just used their on site checker when originally ordering. Andrews and Arnold suggested bonded lines (a little expensive)
In terms of my neighbours – there's 8 flats and four businesses in the premises. None of my neighbours have fibre as it's been the subject of much discussion amongst us (some care some don't).
Message 6 of 16
as I said using the dslchecker with your phne number is the most accurate
your could try writing to openreach and if you get auto reply then send again until you get reply of an actual person
https://www.formwize.com/run/survey3.cfm?id=7214&embed
kinthos
Message 7 of 16
I don't get it.  Isn't your telephone number suggesting you *can* get fibre?  Pretty good speeds too!
If I've been helpful (or amused you) - Click the Star under my name. I'm Just another satisfied BT Customer. 😉
gt94sss2
Message 8 of 16
Cabinet 28 has been enabled for FTTC since 2013.
Cabinet 19 has either just gone live or is about too.
looking at the codelook website, it looks like Openreach are doing some network rearrangement in the area and it's possible the checkers are in the process of being updated.. - hence the conflicting results
Message 9 of 16
that is assuming the database is correct which may be the problem hence why having problems getting a fibre conenction.  having 2 checkers giving 2 different cabinets is a problem
as current speed cabn be up to 16mb then that suggests cab 19 which is not fibre enbale4d yet
papalozarou
Message 10 of 16
@imjolly – thanks again for the info
@kinthos – that's part of the reason I'm confused. When I put the same number into superfast-openreach.co.uk it comes back as being at the field survey stage. If I enter hte number into any service providers checker, it comes back as not able to get fibre.
@gt94sss2 – thanks for that info.
I guess I should ring BT up? Or will they just be checking the same database as openreach (i.e. ending up with Cabinet 19 and no fibre)?
