pompey1898
Expert
Message 1 of 36
Daily disconnects and sporadic slow speeds
I reported daily disconnects, and some slow speeds to BT.  The latter I thought maybe congestion as they appeared around the same times in the morning.  I thought possibly due to businesses in the village starting up.
I had a BT engineer visit yesterday.  He was difficult to understand due to his foreign accent but all he kept saying was he got 40Mbps on his test.  Well of course he did, that's what I get in the afternoon.
Do you think the two issues might be related or have any other ideas please ?
35 REPLIES 35
Message 2 of 36
Re: Daily disconnects and sporadic slow speeds
post stats and btspeedtester results
pompey1898
Expert
Message 3 of 36
Hi @imjolly,
Here are the stats as of now :-
This is a list of your BT Smart Hub settings and current statistics.
Product name:Smart Hub
Serial number:+088047+1741004065
Firmware version:v0.09.05.11160-BT
Firmware updated:Mon Jun 11 14:39:29 2018
Board version:01
DSL uptime:0 days,17 Hours02 Mins57 Secs
Data rate:5.937 Mbps / 47.988 Mbps
Maximum data rate:5.937 Mbps / 48.882 Mbps
Noise margin:5.9 / 3.7
Line attenuation:43.6 / 26.0
Here is a speed test as of now :-
1. Best Effort Test: -provides background information.
 Download Speed
 30.82 Mbps
0 Mbps46.4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 30.82 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-46.4 Mbps .
 Additional Information:
 IP Profile for your line is - 46.4 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 5.4 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 5.4Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Here is a speed test sent to BT on 29-6 :-
Message 4 of 36
apart from only 17hrs uptime stats look good with noise margin down at 3.7db suggesting G.INP active
need btspeedtester results with wired conenction when poor and when good  preferably using IE/Edge
pompey1898
Expert
Message 5 of 36
Uptime was from a disconnect at 01:02, that being after the BT engineer disconnected my router to run a test yesterday at around 5pm.
Will do again when I can but that is not very easy.
Putting speed to one side, what might be causing these frequent disconnects.  I got them with my previous router HH6A, details were on an old thread of mine, but it seems worse since the OR engineer installed the HH6B.
pompey1898
Expert
Message 6 of 36
Hi @imjolly,
Not had any "normal" versus "slow" speeds to post.
However, I am still getting the daily, or sometimes more than one a day, disconnects.
Since this happens almost solely when I am not using the computer, and the downstream speeds remain about the same, it is not too much of an issue.  The only frustration is that I get logged out from some websites, this one included, every time it happens.
Do you , or anyone else reads this, have any ideas why this should be happening please ?
Message 7 of 36
dropping internet connection on a daily basis is not normal and needs investigated
have you checked when disconnected for line noise?
are the disconnections about same time of day suggesting some home interference?
pompey1898
Expert
Message 8 of 36
have you checked when disconnected for line noise? No because, as I think I have said before they happen when I am not using the computer.  The only way I am aware of the disconnects is way after the event when I have been logged out of websites.
The quiet line test has been OK ever since the fault was rectified.
are the disconnections about same time of day suggesting some home interference?Mainly during the night.  I have kept a note of the more recent disconnects, in anticipation of your question, viz :-
01:02, 05:34, 05:45, 02:25, 05:14, 05:50, 03:16 and yesterday at 22:51.
We have nothing switching on and off at those times.
pompey1898
Expert
Message 9 of 36
Hi @imjolly,
For the first time in a long while I had a disconnection while I was actually using the computer. Annoyingly it happened while I was bidding on ebay so I lost the item.
So as you requested I immediately ran a quiet line test and it was silent.
Does this WAN log give you any ideas what might be causing this please.
09:25:32, 01 Aug. WAN Sensing Auto sensing Complete, interface selected
09:25:32, 01 Aug. WAN Sensing Auto sensing Running
09:25:31, 01 Aug. WAN IPv6 Global unicast prefix / length: 2a00:23c2:6306:1f00::/56
09:25:31, 01 Aug. WAN IPv6 Global unicast address allocated: 2a00:23c2:6306:1f00::1/64
09:25:31, 01 Aug. WAN DHCPv6 events: BOUND
09:25:29, 01 Aug. WAN Sensing Auto sensing Complete, interface selected
09:25:28, 01 Aug. WAN DHCPv6 events: INIT
09:25:26, 01 Aug. WAN Sensing Auto sensing Running
09:25:26, 01 Aug. Success - secondary DNS servers
09:25:26, 01 Aug. Success - primary DNS servers
09:25:26, 01 Aug. WAN connection WAN2_INTERNET_PTM connected
09:25:04, 01 Aug. WAN Auto-sensing detected port DSL WAN
09:25:04, 01 Aug. DSL Link Up: Down Rate=49602kbps, Up Rate=5859kbps; SNR Margin Down=0.0dB, Up=0.0dB
09:22:47, 01 Aug. WAN Sensing Auto sensing Complete, interface selected
09:22:46, 01 Aug. WAN Sensing Auto sensing Running
09:22:46, 01 Aug. WAN Sensing Auto sensing Complete, interface selected
09:22:45, 01 Aug. WAN Sensing Auto sensing Running
09:22:39, 01 Aug. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
09:22:26, 01 Aug. DSL Link Down: duration was 19098 seconds
Message 10 of 36
that is almost 14 days stable so wonder if that is '14 day reset' problem  where hub resets every 14 days ish
