Kilfinan
Message 1 of 3,466
Dalkeith Exchange - BT Infinity
Just found out that the rollout of FTTC in my exchange has been put back 9 months when it was previously scheduled for March 2012.
I am utterly furious about this.  Why am I paying the same as everyone else for about 120k download speeds? The web is almost unusable and they are charging me for it! Unbelievable.
BT are a farce.
3,465 REPLIES 3,465
gouledw
Recognised Expert
Message 2 of 3,466
Re: Dalkeith Exchange - BT Infinity
Hi Kilfinan,
If you would be happy to post your Home Hub Stats, and also run a speedtest at http://www.speedtester.bt.com and we may be able to help you out, sounds like you have a profile problem.
Kilfinan
Message 3 of 3,466
Hi
How do I access the stats?
Regards
Tags (1)
gouledw
Recognised Expert
Message 4 of 3,466
Go to http://192.168.1.254/ and go to A-Z top right hand side of the page, navigate to ADSL Status and then post the stats including Attenuation, Sync Speed, Noise Margin and errors etc...
Message 5 of 3,466
I am also on Dalkeith how did you find out the schedule date is now dec 2012?
Kilfinan
Message 6 of 3,466
I found it on this site
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=29017
Click on 'Find Your Area' then Scotland
Message 7 of 3,466
thanks - depressing thoughSmiley Sad
Message 8 of 3,466
I think my exchange is later next year to still never mind something to look forward too
gouledw
Recognised Expert
Message 9 of 3,466
Exchange = No Estimated Date yet / still no Local Authority roll out plans for NGA. 😕
Kilfinan
Message 10 of 3,466
Sorry it took me so long to get these stats.
I'll run a speed test when I cab dig out a cable!
Line stateConnected
Connection time0 days, 0:05:14
Downstream224 Kbps
Upstream320 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.9 dB / 6.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)12.4 dBm / 11.8 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)18 / 0
CRC Errors (Down/Up)1 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)1
