Kilfinan
Message 11 of 3,466
Re: Dalkeith Exchange - BT Infinity
Just run the test and it says 180k which apparently is ok as the max available is 250k!
Guess I need to live with being ripped off by BT as there are no other options around here.
gouledw
Recognised Expert
Message 12 of 3,466
Your speed is very low, even for your attenuation, would you like some pointers at things that may increase it? Just quick tips that may soothe the problem for now...
Message 13 of 3,466
are you connected to the master or better the test socket?  do you have other sockets apart from the master?
have toy tried the quiet line test   dial 17070 option 2  should hear nothing and best with corded phone  if cordless then dull hum is normal
have you removed the orange bellwire from terminal 3?  I would expect better speed than you currently have for your attenuation
Kilfinan
Message 14 of 3,466
Something really bizarre has happened.  Just did a speedtest as the line seemed a little faster and it has gone up to 1.7mb!
In my 3 years in this house it has NEVER been that fast.
What's going on???
Message 15 of 3,466
can you post the hub stats for comparison with previous ones.  btspeedtester as well if possible
Kilfinan
Message 16 of 3,466
It's dropped again!!!!
Line stateConnected
Connection time0 days, 5:38:09
Downstream928 Kbps
Upstream320 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)16.1 dB / 7.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)15.4 dBm / 11.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)258 / 4
CRC Errors (Down/Up)33 / N/A
HEC Errors (Down/Up)N/A / 1
Error Seconds (Local)18
  Hide Details
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
 Download  Speed
 734 Kbps
0 Kbps1000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 734 Kbps
 For your connection, the acceptable range of speeds is 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :928 Kbps(DOWN-STREAM), 320 Kbps(UP-STREAM)
 IP Profile for your line is - 818 Kbps
2. Upstream Test:  -provides background information.
 Upload Speed
 243 Kbps
0 Kbps320 Kbps
>Upload speed achieved during the test was - 243 Kbps
 Upstream Rate IP profile on your line is - 320 Kbps
A couple of days ago the profile was 1.7mb.
If someone can tell me what is going on I'd be grateful.
Message 17 of 3,466
although your connection speed is still low the stats look better and with the higher noise margin there is scope to reduce that to about 6 and that will increase your speed
as I asked before are you connected to the master or test socket?  do you have other sockets apart from the master?
Kilfinan
Message 18 of 3,466
Yes I am connected to the master socket.  It also seems ot be getting slower again!!!
Message 19 of 3,466
do you have other sockets?  if so have you tried connecting to the test socket and leaving for a few days to see if that improves your connection.  it is your direct connection to the exchange
gouledw
Recognised Expert
Message 20 of 3,466
May want to have a look at my guide to improving your speed and socket/equiptment for long lines if you wish ... http://goo.gl/ddnG2
