Storm_Force
Message 1 of 8
Data rate capped?
Earlier in the year I had numerous problems with my broadband speed, several engineer trips later and being moved to a new pair of wires back to the cabinet seems to have helped.
One thing I have noticed is that my data rate seems to be capped and never goes above the figures shown in attachment ( its always has the same rate even when reconnected)  I was hoping it would sort itself out but no luck. I did ring the helpline but they hadn't a clue what I was going on about.
7 REPLIES 7
Message 2 of 8
Re: Data rate capped?
DLM can be quite stubborn and take several weeks to remove banding which your line appears to suffer from. How long has it been stuck at 25M?
Message 3 of 8
your connection time is only 5 days is that due to manual reset or router dropping connection  DLM will only improve speed with stable connection
Storm_Force
Message 4 of 8
Yeah we had a power cut that's why it been 5 days, its probably been around two months since the data rate has been the same.
Moderator
Moderator
Message 5 of 8
Hi @Storm_Force  welcome back and sorry the rate is still capped. I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to help you further.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Storm_Force
Message 6 of 8
I have replied to the pm, thank you.
Storm_Force
Message 7 of 8
Dear Mod Team,
Sorry I missed you call, just to let you know it appears the cap has been lifted so thanks very much for sorting this out for me.
Regards
Gavin
Moderator
Moderator
Message 8 of 8
Hi @Storm_Force  thanks for posting back and glad to hear the cap has been lifted for you. Unless there is anything else you need me to help you with I will close the case.
Cheers
John
Kudos”
