IVIik
Message 1 of 9
Decreased Speed following CAB replacement
So, my cabinet was taken out by a van a few weeks ago (see pic)
My broadband was working on a single wire for a couple of weeks at speed ranges between 10 and 20mpbs, until the cabinet was replaced and my line started syncing and increasing the speed.
But I've always had a solid 80/20 connection, now I've been stuck at 60/17 for the last day or so.
Can replacing the cabinet affect my connection so much, I would have thought a newer cab, would not have made the connection worse.
My guaranteed speed is only 32mbps, so its not as if I can raise a fault for it, can I?
Am I stuck at a slower speed now? Thoughts?
Michael
8 REPLIES 8
imjolly
Message 2 of 9
Re: Decreased Speed following CAB replacement
enter your phone number and post results  delete number but leave exchange and cab
https://www.dslchecker.bt.com/adsl/adslchecker.welcome
post hub stats if hh6 then advanced settings then technical log information
check for line noise
IVIik
Message 3 of 9
Hi thanks for the reply, stats below:
 Exchange DUDLEY is served by Cabinet 5
dslchecker:
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low
VDSL Range A (Clean)51.53510.46.532.4AvailableAvailable--
VDSL Range B (Impacted)5032.410.2626.1AvailableAvailable--
Observed SpeedsVDSL
Max Observed Downstream Speed (Mbps)60
Max Upstream Observed Speed (Mbps)16.99
Observed Date2020-04-03
HomeHub:
Product name:
BT Hub 6A
Serial number:
+084316+NQ63181368
Firmware version:
SG4B1000E020
Firmware updated:
12-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
1 Days, 12 Hours 11 Minutes 40 Seconds
Data rate:
17.00 Mbps / 60.00 Mbps
Maximum data rate:
19954 / 71810
Noise margin:
8 dB / 9 dB
Line attenuation:
32.4 dB
Signal attenuation:
23.7 dB / 32.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5 GB Uploaded / 157 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
HooseInfinity
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
HooseInfinity
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
licquorice
Message 4 of 9
You are getting far faster speed than estimated and have room for improvement when DLM does its stuff. Just be patient
IVIik
Message 5 of 9
Yeah, I know I should be more patient, but I'd be pretty gutted if I don't get back to 80. Working from home ('m BT too) with 2 laptops, the Mrs using netflix and the child on youtube, really hits home about how much speed is actually needed nowadays.
Michael 🙂
IVIik
Message 6 of 9
So here we are 12 days later and I'm stuck at 60/17.
Is there anything that can be done to force a resync?
The HH has been restarted a couple of times during the last 12 days, but there has seemingly been no auto resync for a while.
jeb0007
Message 7 of 9
It maybe because it is the same problem that others have after the latest Firmware update
Firmware version:
SG4B1000E020
Firmware updated:
12-Mar-2020
Yours was done on the 12 March 2020 and your line attenuation etc, is now much different
Line attenuation:
32.4 dB
Signal attenuation:
23.7 dB / 32.4 dB
Do you have a record of what it was before the 12 March
There are lots of comments about this new firmware which have reduced speeds.
IVIik
Message 8 of 9
All, I have from prior 12 Mar is this line, which I took from the techical log
00:01:32, 01 Jan.
dsl:VDSL link Up: Down Rate=71520Kbps, Up Rate=20954Kbps, SNR Margin Down=8.30dB, SNR Margin Up=14.00dB
imjolly
Message 9 of 9
you cannot resync the hub to increase your speed in fact if you get any increase it will be by making sure the hub stays connected 24/7
as you current connection speed is well about your expected range from dslchecker BT are not going to help
