MT10
Message 1 of 4
Desperate for solution to diminishing upload speed
Hello, I'd be really grateful for some help on this as it's causing me huge problems.
My upload speed is registering on the router (Smarthub 2) and independently on Ookla at about 650-750kbs. A 2.5mb file should therefore upload in about 3-4 secs and 10 identical files ie 25mb should be less than 45 secs. I've measured the times they actually take several times over using a stopwatch and these indicate upspeeds of just 83kbs for a single file dropping to 52kbs for all 10, ie way down on what it should be. Download speed is broadly stable at 12-14mb.
The following are all the relevant facts I can think of
Switched to fibre about 3 mths ago, upload speed on ADSL was about 550kbs but file uploads at least kept to that speed.
Incoming line/master socket just checked by Openreach and absolutely fine (a fault down the road).
No difference on the above rates between using a laptop and desktop, both on separate ethernet, or using different router ports.
Changing DNS and disabling antivirus/firewall show only marginal improvements.
I am about 900 yds from the cabinet which I know explains the low rate of 750kbs.
I just don't understand why file uploads are falling so far short of the indicated speed and then slow down even further the more is uploaded. I now need to be uploading things regularly but attempting to upload a file of 1gb had to be abandoned after 4 hrs as it stuck on about 70% completion, I'm having to go to a friend's house to do larger uploads. Surely this must be a fixable problem. Does it sound as if the router's faulty or something not done right 3 mths ago on the cutover to fibre?
Many thanks
3 REPLIES 3
imjolly
Message 2 of 4
Re: Desperate for solution to diminishing upload speed
can you post hub stats if hh6 then advanced settings then technical log information
enter your phone number and post results  leave exchange and cab  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
run btspeedtester and when first test completes then run diagnostic test and post results
https://speedtest.btwholesale.com/
MT10
Message 3 of 4
Hello imjolly thank you for v prompt response. Here are stats, in 2 parts as I'm getting error message doing all in one go
Product code:Smart Hub 2
Serial number:+091301+1932007461
Firmware version:v0.16.02.08304-BT
Firmware updated:Fri Jan 31 12:20:57 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:1 days,22 Hours38 Mins48 Secs
Data rate:754 Kbps / 15.418 Mbps
Maximum data rate:914 Kbps / 18.692 Mbps
Noise margin:6.4 / 6.4
Line attenuation:16.3 / 27.9
Signal attenuation:14.4 / 24.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:2.3 GB Uploaded / 18.0 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-77A6T5
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-77A6T5
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:F0:86:20:1F:D6:18
Software variant:-
Boot loader: 0.1.7-BT (Thu Nov 30 09:45:22 2017
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 12.84
Upload Speed (Mbps) : 0.99
Ping Latency (ms): 21
MT10
Message 4 of 4
second part
Exchange REDHILL is served by Cabinet 25
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLADSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)24153.51.713.1AvailableAvailable--
VDSL Range B (Impacted)23.512.83.51.48.8AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6.5--5.5 to 7.5Available--Yes
WBC ADSL 2+ Annex MUp to 6.5Up to 15.5 to 7.5Available--Yes
ADSL MaxUp to 3.5--2.5 to 7Available----
WBC Fixed Rate2 ----Available--Yes
Fixed Rate2 ----Available----
Max Observed Downstream Speed (Mbps)14.2711.51
Max Upstream Observed Speed (Mbps)0.580.44
Observed Date2019-12-182019-09-29
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date14-02-2020
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
