MaximusPrime
Message 1 of 25
Dialling Code Lookup says I'm connected to wrong Cabinet
Hi,
I checked my number & postcode on Magenta Dialling Code Lookup: https://www.telecom-tariffs.co.uk/codelook.htm
It says my postcode is served from the wrong exchange & cabinet, I am connected to a different exchange & cabinet for sure
Could this be the reason the BT wholesale further tests is giving an error?
Could this be the reason for my bad connection?
24 REPLIES 24
Message 2 of 25
Re: Dialling Code Lookup says I'm connected to wrong Cabinet
The codelook site isn't 100% accurate.
The reason for your bad connection is as you're aware, the distance you are from the cabinet.
The data on a third party website is also unlikely to be causing the error you're getting with the BT Wholesale tester.
Postcodes can sometimes be covered by different cabinets and indeed exchanges depending on how the Openreach network is routed in that area.
MaximusPrime
Message 3 of 25
@Webby,
I received a mail back, yeah, my postcode is serviced by 2 different exchanges causing a problem, probably ok on the BT side
I sent BT wholesale an email asking what the problem with the speed tester is
Message 4 of 25
The speedtest goes through periods of problems on some lines from time to time I doubt if Wholesale will be able to give you an answer as you are not one of their customers
MaximusPrime
Message 5 of 25
@john46,
my disconnection problems started mid January after bad weather
There was a cherry picker fixing lines at the boundary of the 2 exhanges the day after it started
the Further Diagnositics stopped working at this time too
my connection was stable before this
Message 6 of 25
your line problem has no effect on the wholesale speedtest
MaximusPrime
Message 7 of 25
@john46,
I think maybe some settings got corrupted during the fixes after this bad weather
It's like in Software- fix 1 bug create another 2 accidently
Message 8 of 25
Sorry Maximus, you can clutch at as many straws as you like, you won't change the laws of physics. Smiley Wink
Message 9 of 25
sorry you are completely wrong on this your disconnections and the speedtester are totally unrelated you are overthinking things
MaximusPrime
Message 10 of 25
@licquorice,
I don't accept the laws of physics! lol!
My phone cable runs under a cabinet 1km closer to me, I can't accept that they couldn't be bothered to hook me up to that either lol
