Message 11 of 25
Re: Dialling Code Lookup says I'm connected to wrong Cabinet
If they done that for everyone nothing else would ever get done. That cabinet may be newer than your, or older. The network is routed the way it is routed for a reason.
MaximusPrime
Message 12 of 25
@john46,
I had a stable enough 4.7Mb up to that point so somethings changed...
Message 13 of 25
Round and round and round we go!!
MaximusPrime
Message 14 of 25
@Webby,
Message 15 of 25
See link about cabinets and after reading it move on!
http://www.superfast-openreach.co.uk/faq/
There is another cabinet nearby that is already accepting orders, can I get fibre broadband from there instead?
No, the network over which fibre broadband is provided is bespoke, and all premises are served from dedicated fixed distribution points. Many lines are connected via their own overhead or underground link to a nearby green telephony cabinet. There are no interconnections that could be used to move a line from one cabinet to another.
MaximusPrime
Message 16 of 25
@gg30340,
which leads me back to the question - why didn't they hook me up to cabinet 45 when they installed it?
Message 17 of 25
It makes no difference why or why not, the fact is it isn't and it won't be changed.
MaximusPrime
Message 18 of 25
@gg30340,
it does make a difference because once it's in place I'm stuck with it; 1980's network infrastructure
Message 19 of 25
This thread is a repeat of your last thread which was going round in circles. It has been explained fully to you what the problem is. If you are not happy with that I suggest you contact BT directly and ask them to contact Openreach to move your line and see what reply you get from them. I think I know what the answer will be.
I would suggest that like your last thread this thread and any subsequent thread about the same problem should also be locked by the moderators.
Message 20 of 25
All those electrons rushing down the wire don't wear it out!
