Message 11 of 14
Re: Different Pole for FTTP
Technically it’s possible providing the Pole is within 68m.
You could have other issues though as in Planning Stage for FTTP your property is assigned a NAD Key, which is associated with a specific CBT, which in turn is connected to a Particular SASA, which and most importantly is assigned to a Head End Port.
If the CBT on the Pole out front is on the same Head End then they could easily put in a Routing change on the day of Installation.
If the two CBT’s go back to different Head Ends though they it would need to go back to Planning for a NAD Key Reset and depending on Capacity at the adopting Head End Slot they might not be able to do it.
Message 12 of 14
Thanks 36ULW. I ''may'' have found a solution. My BT contract finishes in 3 weeks, and out of the blue our road was targeted by BeFibre's sales team last night. I'd seen their boxes on the poles around us but they weren't in operation last time I checked. Apparently they are now. I explained my problem to their sales guy and he assured me (I know - probably sales patter?) that if needed they could use the alternative pole to supply my property. He did explain it in more detail but It was beyond me - I should have recorded it for you guys to check. You don't pay until it's up and running and I won't cancel with BT until I know it works ok. I'd sooner stick with BT but I've no idea when their FTTP will be activated and I don't like having to tell my daughter 'no 4K film streaming' when I'm trying to work, our present B/B just can't handle it. Fingers crossed!
Message 13 of 14
If an Alt Net is available and you are going to use them , it’s not appropriate or allowed to discuss other operators on this BT Customer forum , FWIW , they will have their own processes and procedures, so it would be between you and them the manner in which they provide service, even if they use Openreach infrastructure via PIA , to locate their equipment.
Message 14 of 14
Apologies. I didn't realise that.
