Newbie
Message 1 of 5
Different broadband speeds down the same road
Hi there,
I live in the post code rm14 3px with basic broadband and speed from 0.1 - 0.3 (ooooooh i hear here say!)
across the road and down the bottom of the dead end road, 2 mins walk they have the postcode rm14 3qh and they get ultra fast bb and speeds of 100+ how on earth can that be am i told that my area cant have fast bb in my area even though the problem is being "worked" on.
i know the issue too.... my postcode connects to the north of the village and those across the road connect from the south, why cant we be on the same as them, its in the area with such a short distance instead of the long distance to the exchange i have at the moment.... any ideas what when where why how?
4 REPLIES 4
Message 2 of 5
Re: Different broadband speeds down the same road
are you a BT broadband customer?
if so enter your phone number and post results  remember to delete number   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Newbie
Message 3 of 5
i am a bt customer and i put my number in and got
on Exchange UPMINSTER is served by Cabinet 3
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsADSLOther Offerings
Availability Date
Premise environmentStatus
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 5.5--3.5 to 7.5Available----
WBC ADSL 2+ Annex MUp to 5.5Up to 0.53.5 to 7.5Available----
ADSL MaxUp to 3--2.5 to 6.5Available----
WBC Fixed Rate2 ----Available----
Max Observed Downstream Speed (Mbps)1.6
Max Upstream Observed Speed (Mbps)0.45
Observed Date2019-11-03
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date11-11-2019
Newbie
Message 4 of 5
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
and a number from down the lane ...
Exchange SOUTH OCKENDON is served by Cabinet 14
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install Process
Left in JumperObserved SpeedsVDSLADSLOther Offerings
Availability Date
VDSL Range A (Clean)9.54.70.80.83.1AvailableAvailable--
VDSL Range B (Impacted)9.54.20.51.22.6AvailableAvailable--
WBC FTTPUpto 330Upto 50--Available1 Stage--
WBC ADSL 2+Up to 1--0.25 to 2Available----
WBC ADSL 2+ Annex MUp to 1Up to 0.50.25 to 2Available----
ADSL MaxUp to 1--0.25 to 2Available----
WBC Fixed Rate0.5 ----Available----
Max Observed Downstream Speed (Mbps)--0.96
Max Upstream Observed Speed (Mbps)--0.45
Observed Date--2018-07-21
VDSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date15-11-2019
Expert
Message 5 of 5
Please edit your second message to remove the number.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
