DavidCo
Expert
Message 1 of 3
Different disconnects HH5
We read about disconnects & reboots, but are we talking about the same issue.
I have noticed that when I check the event log just after a disconnect I cannot find any corresponding entry.
I have also noticed that the VDSL/DSL shows no disconnect (up time)
I have updated to .204 and my up-time shows 4days, 17hours - Great.
I had 2 disconnects yesterday evening (1700hrs) in 30 mins.
The up-time shows nothing & there is no entry in the log.
If there is no entry in the log how can anyone trace the fault.
David
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Different disconnects HH5
How can you tell you had disconnects? Wifi?
If not, I'll try again 🙂
DavidCo
Expert
Message 3 of 3
Hi Ray
No wifi at all. I got fed up with the 'help desk' blaming wifi when I used to call that I disabled all, inc Fon and went cable only.
The only way I can tell, is if it happens when I am sitting at the PC. I then go & check my wifes iMac and confirm.
Yup, help desk used to say that it was a PC fault - hence the iMac check.
I have no idea how many disconnects actually happen because I am not sitting at the PC all the time. Maybe 4-5 hours/day max.
