Message 1 of 11
Digital Voice and Careline use.
Hi,
The Digital Voice system has just been installed at my elderly in-laws property.
can anyone tell me how to correctly connect a  “careline” connection? The other system was just piggy-backed into a standard telephone.
many thanks.
10 REPLIES 10
Message 2 of 11
Re: Digital Voice and Careline use.
Hi @Buddhagb1, welcome to the community and thanks for posting, does the careline need to be connected to a standard phone socket? If so there a socket on the back of the Smart Hub 2. You first need to peel off the cover that says digital voice customers only and behind that there is a green phone socket.
Neil
Message 3 of 11
Hi Neil,
thanks for your prompt reply l will check on my next visit .
Message 4 of 11
Hi @Buddhagb1
I’m guessing, but perhaps a Digital Voice Adapter could be used at any power socket to provide a socket to plug the care line in to.
https://www.bt.com/content/dam/bt/help/user-guides/Digital-Voice-Adapter-userguide.pdf
Message 5 of 11
Yes, that`s all very well, but BT don`t appear to sell the Digital Voice adaptors, although they do supply a user guide.
Message 6 of 11
Thanks Neil this worked but line wasn’t clear.
Message 7 of 11
They do sell a digital voice socket and this was my end fix as it resolved the crackling line via the hub. Another issue has been brought to BT’s attention with regard to a UPS style battery back-up.
the current system advertised does NOT work with digital voice, therefore in the event of loss of mains power care lines will not work.
thanks for everyone’s advice .
regards Gary
Message 8 of 11
Would the careline unit also need a UPS?
Message 9 of 11
I believe this would depend on the actual careline unit, for ours it needs plugging in as well as a phone line so yes. The current one available from BT is not compatible with Digital Voice and this is being looked into.
Based on previous threads I believe BT have some responsibility to ensure the system works normally.
hope this helps
Message 10 of 11
I believe this to be correct depending on the actual system.
