Recka19
Message 11 of 14
Re: Disconnections & Speed issues
Ok so like clock work my hub disconnects - I tested it as you have shown me, and for literally a second the line crackled, but then went silent for the rest of the time testing
Message 12 of 14
Then you have an unresolved intermittent line fault.
As this is a multiple repeat fault,
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Recka19
Message 13 of 14
Thanks keith
Moderator
Moderator
Message 14 of 14
Hi @Recka19
Welcome to the Community and thanks for your post!
Sorry that you're having problems with your broadband.  I appreciate the amount of time you have already spent trying to get this sorted out.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
