xer0w
Message 1 of 4
Disconnections
Hi,
I have Infinity 2 unlimited which is usually stable and fast, but every 5 days the line disconnects for about a minute (sometimes less) whilst the modem reconnects (I can see the drop and reconnection in the log).
I have had a BT engineer visit and perform a line test, everything is fine, I have also done the recommend tests via the master test socket, which doesn't make any difference.
I have a DrayTek Vigor 2762ac setup with the latest .BT firmware and configured as per the instructions for a BT VDSL connection.
My line stats are ok, as follows. Speed is good (74/18)
Any help or guidance appreciated.
3 REPLIES 3
Message 2 of 4
Re: Disconnections
this sort of disconnection is more often after 14 days with some at 7 days and from memory a couple at 5 days but as long as your conenction speed is not suffering there is nothing you can do.  I used to have the 14 day reset for months and then it just stopped dropping and currently at 31 days with last reset due to firmware update
Message 3 of 4
Re: Disconnections
It does not matter which router you use, you will still see a momentary disconnection as DLM makes any adjustments. This normally happens early morning between 3-5am, so should not cause any issues.
xer0w
Message 4 of 4
Re: Disconnections
I've read a few posts elsewhere regarding the 14 and 7 day disconnects, although these were using a BT HH, but I guess if its dropping on the DSLAM then its not specific to cust equipment.
I'll leave it for a few more weeks and hopefully the DLM profile will settle down.
Thanks for the responses.
