purplemonkeyspank
Message 1 of 8
Do BT Activate Your Broadband Earlier Than They Quote When Ordering?
I ask because I was told my phone line and bb will be up and running on the 26th but out of curiosity I tried calling the new phone number I was given and it rings. Does this mean my bb is is setup too?
The BT Smart Hub won't be here until tomorrow according to online order tracking so can't check that way. Is it possible BT Activated the bb as well or is the phone line just a fluke?
7 REPLIES 7
Message 2 of 8
Re: Do BT Activate Your Broadband Earlier Than They Quote When Ordering?
normally activation is on the day specified  looks like you phone is conencted but I would expect the broadband to be on the date stated
purplemonkeyspank
Message 3 of 8
Aw. Thought I got lucky for a second there. Ah well. Thanks.
purplemonkeyspank
Message 4 of 8
Well the broadband connection indeed active before the date specified on the 26th. The Smart Hub came today.
Plugged it in and vioala. Internet. Download speed is half of the "up to" 80Mb/s but that may be down to the DLM. Right?
Message 5 of 8
Unlikely DLM is restricting speed
post stats from hub. Advanced settings then technical log information
enter your phone number and post results remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
purplemonkeyspank
Message 6 of 8
Yeah checked that site well before ordering. Tried yesterday just to double check and it says up to 80Mb/s
https://imgur.com/0Cffz55
https://imgur.com/mNUAjre
That's the stats page. On Sky I remember there being more info.
Message 7 of 8
Speed seems low compared to  dslchecker. I think you need to wait until activation date. Either that or you have a problem with your line/wiring
purplemonkeyspank
Message 8 of 8
Yeah I did have a faulty line with Sky. It's why I moved to Virgin. I'll wait until after the scheduled date of activation before letting BT know.
Thanks for taking the time so late on a weekend. Thanks again and have a good one.
