IPLondon
Message 1 of 8
Do I need BT engineer for lower speeds?
On speedtest.net I am getting around 20-35Mbps downstream whereas I am on 76mbps connection. What do I need to do next?
BT HH5:
BT Broadband Availability checker:
7 REPLIES 7
imjolly
Message 2 of 8
Re: Do I need BT engineer for lower speeds?
run btspeedtester and post results  must be done with ethernet connection not wireless
https://speedtest.btwholesale.com/
Starwire
Recognised Expert
Message 3 of 8
BT might send out one of their Engineers first to do a Home Environment Check it the Line Tests OK. If he/she says everything in the house is OK then they’ll request Openreach do a Network Check.
But if it tests faulty then they’ll usually arrange for an Openreach Engineer to attend first.
IPLondon
Message 4 of 8
Over wired connection 😲
But over WiFi (sat next to Hub):
over Wifi (in other room):
Should I put LAN cables all over the house Or is there a better way?
imjolly
Message 5 of 8
your wifi channels are on auto so try and select channels manually.  try using a wifi analyser on your mobile which will give you the surrounding networks and the channels in use - then pick a less congested channel or one where you wifi signal is the strongest
IPLondon
Message 6 of 8
Is my hub on the best channel?
imjolly
Message 7 of 8
that looks ok for your 2.4ghz network   what about the 5ghz?
IPLondon
Message 8 of 8
Unfortunately my laptop does not take 5Ghz. What would be the best option:
1) buying a second Wifi router which plugs into BT HH for example Netgear Nighthawk?
2) powerline adapter
3) 5Ghz USB dongle which plugs into laptop?
