Message 1 of 4
Do I need to use the BT Smart Hub 2 with FTTP?
Do I need to use the BT Smart Hub with the BT Fiber To The Premise setup? I have a Ubiquity Dream Machine as my main router and wifi unit and have already turned off wifi on the smart hub but if I can completely bypass it that would be a lot better.
3 REPLIES 3
Message 2 of 4
Re: Do I need to use the BT Smart Hub 2 with FTTP?
If you don't need Digital Voice service (DECT based and working only with SH2) then NOPE, you don't need SH2 on FTTP.
You will need configure your router to PPoE connection and that's it.
In case of any trouble, you will need to place on SH2, while BT will refuse any support without SH2
Message 3 of 4
Thanks for the info! Is there any info on here on what PPoE settings I need?
Message 4 of 4
There are countless posts on the forum detailing the settings if you care to look, but once again they are
Username bthomehub@btbroadband.com
Password BT
