Message 1 of 3
Does external wall insulation impact on FTTP installation?
I'm considering upgrading to Full Fibre but I have external wall insulation. Does this have an impact on the FTTP installation?
2 REPLIES 2
Message 2 of 3
Re: Does external wall insulation impact on FTTP installation?
A cable will need to enter your property from the outside. Whether it has to go through a wall depends on the specifics of your property. If there is an existing cable  entering  it might be possible to use the same aperture.
I don’t know specifically about external wall insulation but I don’t see why it would be an issue provided there was adequate sealant applied to the entry point to prevent water ingress.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 3
Thank you Steve
