wecpc
Message 1 of 25
Download Speed Drop and Upload Speed Halved since firmware update on 16/01/15
I noticed that my speeds have been dropping from their normal of 62/15 to as low as 49/8 over the last week or so. I then looked in the event log and noticed a firmware update on the 16th Jan and since then on the WAN details PPOE kept going down and up every 16 hours or so taking my speeds down with it. I also noticed that the Line attenuation and Signal attenuation on the upload side had increased to 28.1 / 19.7 and 28.0 / 19.5, whereas before all the figures were around the 19 figure. I rebooted the hub last night as I thought things could not get any worse but they did. So I shut everything down overnight and rebooted the hub this morning folllowed by my server and then my PC. The download speeds had increased very slightly but the upload speeds still stayed around 8 instead of their normal 15-16.
I have had trouble ever since this was installed late last year and eventually an engineer came out and fixed several faults outside and one on my incoming connection as well as fitting the latest wall plate and things have been fine since then, that is until a few days ago.
Colin
24 REPLIES 24
Distinguished Guru
Message 2 of 25
Re: Download Speed Drop and Upload Speed Halved since firmware update on 16/01/15
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
wecpc
Message 3 of 25
Here they are:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ43010082
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 16/01/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 06:52:03
6. Data rate:8978 / 61355
7. Maximum data rate:10564 / 59996
8. Noise margin:5.8 / 5.8
9. Line attenuation:28.1 / 19.7
10. Signal attenuation:28.0 / 19.5
11. Data sent/received:104.4 MB / 1.2 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
Distinguished Guru
Message 4 of 25
Looks like your upload will struggle to get more than 10 never mind 15.
I think you have noise affecting your line, this could be caused by a fault.
Can you post what the DSL checker estimates for your line please? www.dslchecker.bt.com
wecpc
Message 5 of 25
                                         High            Low       High              Low
FTTC Range A (Clean)59.639.316.110--Available
FTTC Range B (Impacted)50.828.215.97--Available
WBC ADSL 2+Up to 13--7.5 to 17.5Available
WBC ADSL 2+ Annex MUp to 13Up to 17.5 to 17.5Available
ADSL MaxUp to 6.5--5.5 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
Distinguished Guru
Message 6 of 25
Sorry, I should have said please delete your phone number
wecpc
Message 7 of 25
I have corrected that.
I have had upload speeds of 16+ for a couple of months with no problems, but it seems funny that all this co-incided with a firmware update.
Here a few Speedtest.net results:
2/2/2015 10:08 PM GMT81.129.10.24959.25 Mb/s6.85 Mb/s12 msAshford< 50 miShare
  28/1/2015 4:10 PM GMT86.185.200.10361.71 Mb/s15.57 Mb/s11 msLondon~ 50 miShare
  5/1/2015 12:32 PM GMT86.134.40.5061.02 Mb/s16.25 Mb/s1 msCanterbury~ 50 miShare
  1/1/2015 12:44 PM GMT86.166.229.8262.82 Mb/s15.10 Mb/s0 msHemel Hempstead~ 50 miShare
  31/12/2014 9:48 PM GMT86.166.229.8262.82 Mb/s15.44 Mb/s10 msWelwyn Garden City~ 50 miShare
  31/12/2014 9:47 PM GMT86.166.229.8262.80 Mb/s15.44 Mb/s0 msLondon~ 50 miShare
  29/12/2014 3:39 PM GMT86.177.250.20362.70 Mb/s16.39 Mb/s7 msLondon~ 50 miShare
  29/12/2014 3:36 PM GMT86.177.250.20362.82 Mb/s15.50 Mb/s0 msLondon~ 50 miShare
  26/12/2014 10:50 PM GMT86.134.43.18363.97 Mb/s16.30 Mb/s8 msLondon< 50 miShare
  23/12/2014 4:10 PM GMT86.134.43.18363.98 Mb/s16.32 Mb/s7 msLondon< 50 miShare
  22/12/2014 12:56 PM GMT86.134.43.18364.04 Mb/s15.32 Mb/s0 msLondon< 50 miShare
  22/12/2014 12:54 PM GMT86.134.43.18363.80 Mb/s16.33 Mb/s8 msLondon< 50 miShare
  21/12/2014 10:15 AM GMT86.156.232.7664.00 Mb/s16.26 Mb/s15 msMaidstone< 50 miShare
  21/12/2014 10:09 AM GMT86.156.232.7664.00 Mb/s16.34 Mb/s14 msMaidstone< 50 miShare
  21/12/2014 9:51 AM GMT81.152.88.23363.89 Mb/s15.79 Mb/s10 msWelwyn Garden City~ 50 miShare
  20/12/2014 3:44 PM GMT81.152.88.23363.63 Mb/s14.48 Mb/s10 msMaidstone< 50 miShare
  18/12/2014 5:31 PM GMT86.156.232.3163.63 Mb/s15.68 Mb/s0 msWelwyn Garden City~ 50 miShare
  17/12/2014 5:02 PM GMT86.166.229.21663.85 Mb/s15.07 Mb/s0 msHemel Hempstead~ 50 miShare
  16/12/2014 3:06 PM GMT86.166.229.21663.64 Mb/s15.01 Mb/s0 msHemel Hempstead~ 50 miShare
  16/12/2014 1:25 PM GMT86.166.229.21663.64 Mb/s15.20 Mb/s0 msHemel Hempstead~ 50 miShare
  16/12/2014 1:24 PM GMT86.166.229.21663.66 Mb/s15.75 Mb/s10 msLondon~ 50 mi
Distinguished Guru
Message 8 of 25
True, however it's the noise margin where the problem lies I think. The target is 6 but they are currently below that meaning you have no headroom for an increase in data rate - as the Maximum data rate suggests.
Message 9 of 25
I could be totally wrong here as I don't use a HH, but from what I can gather from the forum, before the firmware update the HH5 didn't provide attenuation and SNR figures for upload. If the HH5 was unable to provide those figures how would the DSLAM be able to adjust the speed to give a 6dB margin? Presumably it didn't and thus upload speeds could have been higher before the firmware change.
wecpc
Message 10 of 25
I agree regarding the noise margin but nothing has changed here at all, unless other faults have occured outside yet again. So what do I do now, I expect I have to talk to the script jockey's in India again but last time they achieved absolutely nothing apart from eventually sending out an engineer who fixed the problem. But that took dozens of phone calls and email complaints to achieve that.
Colin
