Alan63
Expert
Message 1 of 6
Download not come back after errors. DLM ?
Hey everyone,
This is annoying : a while back I had some rewiring done in my home. I knew it was going to interfere with my broadband and it did with lots of errors reported, I was ok with that knowing that it was temporary and the DLM would sort it out.
My max profile went from 20/60 to 10/30 then over 4 weeks back to 20/60 . So that’s super. BUT my attained rates are not back and over past 6 weeks it has partially come back to 17/29 (the download is 29,997) and there it has stayed like a stubborn mule!
The attained upload is fine as 17 is pretty much the most I’ve ever got but the download is clearly not recovering. Around 55-57 was the normal.
What’s a good course of action to trigger it back to its normal levels after waiting for DLM?
5 REPLIES 5
Message 2 of 6
Re: Download not come back after errors. DLM ?
can you post stats from your router if hh6 then advanced settings then technical log information
is there any noise on line   dial 17070 option 2  should be silent and best with corded phone
Alan63
Expert
Message 3 of 6
Hi IMJolly - thanks for coming back to me.
I've attached the line stats (they've been telnet'd). Quiet line apart from very faint kind of  'hushing'  - but at my age my ears themselves make that noise!!
Status: Showtime
Retrain Reason: 1
Last initialization procedure status:   0
Max:    Upstream rate = 21090 Kbps, Downstream rate = 61468 Kbps
Bearer: 0, Upstream rate = 17000 Kbps, Downstream rate = 29997 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        16.3            8.3
Attn(dB):        17.9            0.0
Pwr(dBm):        12.6            7.4
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              -6
B:              130             163
M:              1               1
T:              0               0
R:              16              12
S:              0.1381          0.3047
L:              8513            4621
😧              4               2
I:              147             176
N:              147             176
Q:              4               2
V:              2               1
RxQueue:                125             115
TxQueue:                25              23
G.INP Framing:          18              18
G.INP lookback:         25              23
RRC bits:               24              24
                        Bearer 1
MSGc:           90              58
B:              0               0
M:              2               2
T:              2               2
R:              16              16
S:              10.6667         16.0000
L:              24              16
😧              1               1
I:              32              32
N:              32              32
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               0
OHFErr:         0               0
RS:             1244009716              255871
RSCorr:         2298768         65062
RSUnCorr:       0               0
                        Bearer 1
OHF:            21226272                337670
OHFErr:         0               0
RS:             127357261               3632381
RSCorr:         79              261
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         929897896               3715
rtx_c:          9688            11857190
rtx_uc:         68838           28519161
                        G.INP Counters
LEFTRS:         20              22591
minEFTR:        29991           17000
errFreeBits:    242173672               1723659284
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    2487968405              0
Data Cells:     821652188               0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             10              0
SES:            10              0
UAS:            58              48
AS:             340949
                        Bearer 0
INP:            54.00           55.00
INPRein:        1.00            1.00
delay:          0               0
PER:            0.00            0.00
OR:             0.01            0.01
AgR:            30227.58        17156.70
                        Bearer 1
INP:            2.50            4.00
INPRein:        2.50            4.00
delay:          0               0
PER:            16.06           16.06
OR:             47.81           31.87
AgR:            47.81   31.87
Bitswap:        255359/255360           13519/13569
Total time = 1 days 58 min 14 sec
FEC:            2319435         67427
CRC:            560             0
ES:             10              0
SES:            10              0
UAS:            58              48
LOS:            1               0
LOF:            8               0
LOM:            0               0
Latest 15 minutes time = 13 min 14 sec
FEC:            39              13
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            17              18
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 58 min 14 sec
FEC:            2365            184
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 24 hours 0 sec
FEC:            1047415         18488
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Since Link time = 3 days 22 hours 42 min 27 sec
FEC:            2298768         65062
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Message 4 of 6
any line noise will more than likely stop the DLM from getting conenction back to 'normal' speed  if you can hear any noise apart from announcements on the quiet line test then you need to report a phone fault not broadband to 151
you currently are stuck in a banded profile mainly due to the resets/drops in connection when work was being done
Alan63
Expert
Message 5 of 6
Thanks again. I’ll do that .
And will the banded profile sort itself now the issue causing the errors has been resolved?
Message 6 of 6
banding should normally start to release 3/5 days provided line is stable and you have fixed the errors problem
