Lingwood
Message 1 of 3
Download ok upload less than 0.1
Since install about 2 months ago we have had nothing but problems.
Numerous Openreach "engineers" out numerous phone calls to Bt and me in the middle
Today engineer came out and saw green light on ont go off and be said that should not do that
He say speed test at 50 ish down and less than 0.1 up
Hub 6 is now on and off all time blue and orange
When orange upload says about 100 plus but not working
Eningeer today spoke to a PTO who sounded like he knew the issue given the upload issues
They say issue is exchange and only us on this new card and this bit is owned by Bt and not Openreach?
Emailed Bt after this and said if in 48hrs not fixed cancling direct debit....got phone call within a couple hours but could not do anything as still not got back engineers notes from today
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Download ok upload less than 0.1
@Lingwood I'm sorry to see you're having problems with your connection speed. I presume you have Fibre to the Home if you've an ONT installed?  It sounds like Openreach and Wholesale have had to work together on this fault if it's a problem with the card.
Did they manage to get that sorted or provide you with any further updates since?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Lingwood
Message 3 of 3
Yes it looks like it was fixed yesterday.
They had to change the card at the exchange. As Said we only ones on this card so no others to compare to
Now getting about 10 upload and 50 down
