mrt1981
Message 11 of 26
Re: Download speed dropped to a quarter of my "minimum" speed. Speed checker says my speed
Is that what's going on then? Is it ever going to relent if they never find this line fault that is proving so elusive?
Message 12 of 26
the DLM will never bring your speed back up as long as your line is unstable and keeps dropping conenction   you will need weeks of stable connection not just a few days
mrt1981
Message 13 of 26
Ok, frustrating but I can accept that. However... how am I supposed to get weeks of stable connection when BT can't find the fault? The latest fault that was generated yesterday by the diagnostics tool ("unable to make phone calls" I think  was what it came up with) has disappeared from my account. Not closed, but no longer showing as open either. Simply disappeared.
Moderator
Moderator
Message 14 of 26
@mrt1981 is the land line working at the moment? Are you able to make and receive calls ok?
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
mrt1981
Message 15 of 26
Hi @NeilO, I'm at work at the moment so can't check but I tried the quiet line test a couple of days ago and it was completely silent. The line currently appears to be working as I am able to log in to my IP camera (and can see the hub light is blue).
I admit I was a bit curious why the last fault detected was "loss of phone" when the phone line was working at the time, but not exactly surprised given that it's not been detecting faults when I didn't have a connection, and is detecting faults when the connection is up.
Moderator
Moderator
Message 16 of 26
@mrt1981 I think we'd be best running a few tests for you to see if there are in fact any faults on the line.  I'll send you a private message with details on how you can contact the mod team.
Kudos”
mrt1981
Message 17 of 26
@NeilO Thanks, PM sent.
mrt1981
Message 18 of 26
@NeilO a bit more info - just had a call from an openreach engineer who was sent to check the line (guess that fault is still active but just not showing on my account for some reason). He said he couldn't find any problem between the house and exchange and wanted to check the internal wiring. Unfortunately no one is in today, so he said he'll leave the fault open and I'd need to book an appointment through BT
Distinguished Guru
Distinguished Guru
Message 19 of 26
The mods will take care of that for you.
Moderator
Moderator
Message 20 of 26
@mrt1981 I can see my colleague @PaddyB has picked up your case and has been in touch.
Kudos”
