Nathan
Newbie
Message 1 of 5
Downloading 300KBs per second when I am meant to be downloading 3MB per second
Download speed.png Hello,
I am a BT infinity customer and I am paying for 3MB per second internet, but all of a sudden my internet connection has dropped so now it takes longer to access pages and also download games. I am a gaming type of person and this is unbearable I would a preciate it if you could help me out because I have had 3 BT engineers round over the span of 3 years and I do not want there to be another one.
Thanks for reading
-Nathan
4 REPLIES 4
Message 2 of 5
Re: Downloading 300KBs per second when I am meant to be downloading 3MB per second
can you please run the further diagnostics test of the BT Speedtest and post back its results http://speedtest.btwholesale.com/
then we can help you further
Homer_J
Message 3 of 5
300 K(thousand) Bytes per second.
Your connection is 3M(million) bits per second.
8 bits in a byte, then you have overheads so for ease of maths use 10x so you are getting close on 3,000,000 bits per second.
You are getting your full rate.
seab20
Expert
Message 4 of 5
If the OP has infinity then 3MBps (megabytes not bits) should be easily achievable as that would be 24Mbps a fraction of the 76Mbps max connection speed of infinity
Sage
Sage
Message 5 of 5
a) Assuming the OP is on Infinity 2 (Infinity 1 is only 40mbps)
b) Assuming the OP is connecting via ethernet.
c) Assuming if wireless that the card is wireless "N" and not wireless "g"
