tashle101
Message 1 of 10
Downspeed improved up dropped ?
Been having issues for a while with slower than normal download speed used to get 68 dropped to 40-50 down and 14 up, Few days ago started to get a few disconnections during the day so reconnected the smarthub so I could use the BT fault system, No fault was found but my speed changed to 72 down 2 up ?? Why has the upload dropped so much when I used to get a constant 14+ ??
Any help will be greatly appreciated
Product name:
BT Hub 6A
Serial number:
+084319+NQ61939976
Firmware version:
SG4B1000B522
Firmware updated:
21-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 20 Hours 28 Minutes 35 Seconds
Data rate:
2.73 Mbps / 71.67 Mbps
Maximum data rate:
3245 / 76152
Noise margin:
8.2 dB / 4.1 dB
Line attenuation:
17 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4690 MB Uploaded / 12515 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
LoveShack
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
LoveShack CCTV-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:0A:45:1D
Software variant:
Boot loader:
7.33.1
9 REPLIES 9
imjolly
Message 2 of 10
Re: Downspeed improved up dropped ?
Cañ you enter your phone number and post results. Remember to delete number https://www.dslchecker.bt.com/
tashle101
Message 3 of 10
tashle101
Message 4 of 10
Decided to reboot the modem and it seems to have fixed the issue
tashle101
Message 5 of 10
Been getting a few disconnections does the following show what might be happening ?
10:20:27, 01 Feb.
:HTTP UserAdmin login from 192.168.1.169 successfully
10:19:25, 01 Feb.
eth3:IGMP join received for group 224.0.1.187 on interface eth3
10:19:25, 01 Feb.
wl0:IGMP join received for group 239.255.255.246 on interface wl0
10:18:41, 01 Feb.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
10:18:38, 01 Feb.
ppp1:TR69 creating new session with ACS
10:18:32, 01 Feb.
10:18:30, 01 Feb.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
10:18:30, 01 Feb.
ppp1:TR69 receiving InformResponse message
10:18:29, 01 Feb.
ppp1:TR69 event found : 4 VALUE CHANGE
10:18:28, 01 Feb.
ppp1:TR69 sending Inform message
10:18:26, 01 Feb.
10:18:25, 01 Feb.
10:18:23, 01 Feb.
10:18:23, 01 Feb.
:HTTP UserBasic login from 192.168.1.169 successfully
10:17:34, 01 Feb.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
10:17:34, 01 Feb.
BR_LAN:The LAN DHCPv6 Server is active
10:17:34, 01 Feb.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
10:17:33, 01 Feb.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
10:17:33, 01 Feb.
BR_LAN: Allocated prefix = 2a00:23c5:c415:bc00::/64 (valid time = 2026291200 / preferred time = 2026291200)
10:17:33, 01 Feb.
BR_LAN: Allocated address = 2a00:23c5:c415:bc00:924d:4aff:fe0a:451d (valid time = 2026291200 / preferred time = 2026291200)
10:17:33, 01 Feb.
10:17:33, 01 Feb.
ppp1: Allocated prefix = 2a00:23c5:c415:bc01::/64 (valid time = 2026291200 / preferred time = 2026291200)
10:17:33, 01 Feb.
ppp1: Allocated prefix = 2a00:23c5:c415:bc00::/56 (valid time = 2026291200 / preferred time = 2026291200)
10:17:33, 01 Feb.
ppp1: Allocated address = 2a00:23c5:c415:bc01:924d:4aff:fe0a:451b (valid time = 2026291200 / preferred time = 2026291200)
10:17:33, 01 Feb.
10:17:33, 01 Feb.
BR_LAN:The LAN DHCPv6 Server is inactive
10:17:33, 01 Feb.
ppp1:WAN DHCPv6 Mode : Statefull
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:33, 01 Feb.
10:17:32, 01 Feb.
10:17:32, 01 Feb.
10:17:32, 01 Feb.
10:17:32, 01 Feb.
tashle101
Message 6 of 10
Can anyone make sense of it ?
tashle101
Message 7 of 10
Speed seems to have dropped again
imjolly
Message 8 of 10
are you using wireless or ethernet to run btspeedtester?
can you post the router stats again please
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
tashle101
Message 9 of 10
I used ethernet connection for speed test
Havent got a corded phone but on wireless phone it was a bit crackely,
I checked the outside cable last week and got up a ladder to check where it connects to the house as a bit of rubbish had blown up there and if i touch the cable it disconnects the Internet connection tried this 2-3 times and got the same result so not sure if this is causing an issue ?
Restarted the modem as internet froze
imjolly
Message 10 of 10
if you have crackle on quiet line test with corded phone then I would recheck test from test socket with filter and if still hear crackle then report phone fault not broadband to 151 and get engineer visit  you could mention to engineer about the outside line problem when he is there
