Miroz1983
Message 1 of 11
Downstream set lower than guranteed speed
Hi
I've been with BT for 21 months now and recently noticed that downstream speed is set at 40Mbps where guaranteed speed I should get is 50Mbps. I've already asked BT to resolve the issue but nothing has happened this is why I'm leaving. Can I claim back for the speeds I was promised but never received?
Miro
10 REPLIES 10
imjolly
Message 2 of 11
Re: Downstream set lower than guranteed speed
Enter your phone number and post results remember delete number. https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Post hub stats. If hh6 then advanced settings then technical log information
did you report a fault to 151?
Miroz1983
Message 3 of 11
I have reported issue couple months ago and nothing been done.
imjolly
Message 4 of 11
Is there any noise on your phone line. Dial 17070 option 2 should be silent and best with corded phone
Miroz1983
Message 5 of 11
No, it is completely silent.
imjolly
Message 6 of 11
Can you post your hub stats
pippincp
Sage
Message 7 of 11
Looking at the checker results I cannot see how you've got a 50Mb guaranteed minimum. Still waiting for hub stats.
Miroz1983
Message 8 of 11
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65176370
Firmware version:
SG4B1000E01E
Firmware updated:
28-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 5 Hours 27 Minutes 23 Seconds
Data rate:
5.00 Mbps / 40.00 Mbps
Maximum data rate:
5348 / 51337
Noise margin:
6.4 dB / 8.6 dB
Line attenuation:
18.5 dB
Signal attenuation:
0 dB / 18.5 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
136 MB Uploaded / 1596 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-97T5
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-97T5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:88:FC:41
Software variant:
Boot loader:
7.33.1
licquorice
Message 9 of 11
From the checker results it looks as though either DLM has banded the line at 40M or it has been mis-provisioned.
Posted before stats shown, stats confirm supposition.
imjolly
Message 10 of 11
Connection time only 5hrs was that manual reset or hub dropping connection
if you are having problems with your hub groping internet connection then looks like as @licquorice  suggested that DLM  has put you in a banded profile to try and stabilise your connection
