hobb09
Message 1 of 22
Dramatic drop in download speeds
Hello,
I'm experiencing a huge drop in download speeds as below.  I have run through the fault diagnostics and the network checks are picking up the following "Our initial checks show that the connection between your Hub and our network is slow."
My hardware hasn't changed, same router, same ADSL filter, same master socket. I've done a quite line test and the line is silent, I've triend a second ADSL filter, and also tried the test socket directly, all with no improvements. Any ideas what could be casuing this?
Many thanks
21 REPLIES 21
Message 2 of 22
Re: Dramatic drop in download speeds
your down speed is terrible and your conenction stats are not good either
can your factory reset the hub by pressing the recessed button on back and holding 20/30 secs until lights flash  then connec to test socket with filter, turn off smart setup in hub and then post the router stats like before   see if that improves figres  do you have another modem cable you can use to connect hub to filter
hobb09
Message 3 of 22
Hi,
Here are the results direct from the test socket after factory reset of the hub:
I don't have a spare cable to hand but could get one to see if it makes any difference.
Message 4 of 22
that has not helped conenction speed but has significantly improved your attainable speed
are you connecting direct to filter in test socket without any phone extension cable?  when in test socket check there is no dial tone at any extension socket
hobb09
Message 5 of 22
Hi again,
yes from the filter directly into the test socket, no extension.
Could it be a faulty hub?
Message 6 of 22
Are you getting dial tone with a phone at the test socket, looks like one wire has become disconnected?
Message 7 of 22
If you are using test socket and quiet line test ok then phone CS and get engineer visit as speed below estimated and also handback speed
Message 8 of 22
@hobb09
Already posted that did quiet line test and line was quiet so wires appear connected
Message 9 of 22
whoops, missed that although it does have all the symptoms of one wire disconnected.
Message 10 of 22
I agree but must be something else if quiet line test is ok with no noise
