Message 11 of 22
Re: Dramatic drop in download speeds
Could be one wire disconnected in DSLAM but needs an engineer visit in any case.
hobb09
Message 12 of 22
Hi all,
Sorry for delayed reply, I had to head out.
Spoke to BT through the live chat and they have booked a slot for an engineer to visit. Thanks for all the advise nonetheless.
Moderator
Moderator
Message 13 of 22
Hi @hobb09  thanks for the update and do drop back and let us know how you get on with the engineer visit.
Cheers
John
hobb09
Message 14 of 22
Hello,
I had an engineer visit this afternoon and he played around and also performed a DLM reset.
here are the hub stats now:
So, download speed has improved a little but is still much lowe than what should be achieved, maximum data rate also seems low? Is this normal?
I know after a DLM reset it can take a while for speeds to recover back to normal but still, should it be this low?
Thanks!
Message 15 of 22
There's still something not right, your max rate was 25M previously.
Moderator
Moderator
Message 16 of 22
Hi @hobb09 ,
Thanks for getting back following the engineer visit. @licquorice  is correct. It still looks like there’s a problem with the connection. Are you still in contact with the faults team? If not then we might need to take a closer look at this for you.
Cheers
David
hobb09
Message 17 of 22
Morning,
I spoke to the live chat again but they suggested just monitoring the speeds for 48hrs and said that it should recover.
I just don't understand why the max data rate has dropped so low. Is that likely to recover? If not I'll get on the phone and request another engineer visit.
Cheers
Message 18 of 22
They always say that, it won't, you need another engineer.
hobb09
Message 19 of 22
Ok thank you
Moderator
Moderator
Message 20 of 22
Hi @hobb09 ,
Thanks for the quick reply. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
David
