LJ50
Message 1 of 25
Draytek Vigor 2750 / Infinity connection problems
Hi all,
After a fairly torturous experience (another story....) I was finally reconnected to Infinity on Thursday this week, after moving house.
I thought I would leave the ECI model and HH4 plugged in for a few days to make sure everything was stable, which it has been, before plugging my Draytek Vigor 2750n back in. I used the Draytek for not long short of 18 months for my Infinity connection at my old property and no issues whatsoever. Rock solid connection, constantly.
So, I am frustrated and confused that after plugging the Draytek in at my new home, it is going through an apparently contant loop of the VDSL status (profile 17a) moving from "Idle", to Handshake, into "Training" then "Showtime", followed 30 seconds to a minute later by the WAN status being populated, the text turning green and then me having a connection and being able to reach Google, bbc.co.uk, etc.
And then about 30 second to 1 minute later...the cycle starts again. VDSL status turns red, moves to Idle, Handshake, etc all over again.
The log doesn't see to give much away to me, but is pasted below in case anyone else can make sense of it.
My thanks in advance.
LJ
Sep  8 18:49:50 Vigor2750 syslog.info syslogd started: BusyBox v1.11.2
Sep  8 18:49:57 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPINFORM(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1
Sep  8 18:49:57 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPACK(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1 ******-PC
Sep  8 18:50:57 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPINFORM(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1
Sep  8 18:50:57 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPACK(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1 ******-PC
Sep  8 18:51:58 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPINFORM(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1
Sep  8 18:51:58 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPACK(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1 ******-PC
Sep  8 18:52:17 Vigor2750 user.notice root: [WAN] ifdown all wan...
Sep  8 18:52:17 Vigor2750 local4.notice root: ========== ifdown voipwan
Sep  8 18:52:18 Vigor2750 local4.notice root: ========== ifdown iptvwan
Sep  8 18:52:18 Vigor2750 local4.notice root: ========== ifdown mngtwan
Sep  8 18:52:19 Vigor2750 local4.notice root: ========== ifdown wan
Sep  8 18:52:19 Vigor2750 local4.info pppd[4686]: Connect time 3.8 minutes.
Sep  8 18:52:19 Vigor2750 local4.info pppd[4686]: Sent 158598 bytes, received 803516 bytes.
Sep  8 18:52:19 Vigor2750 local4.debug pppd[4686]: Script /etc/ppp/ip-down started (pid 22150)
Sep  8 18:52:19 Vigor2750 local4.debug pppd[4686]: sent [LCP TermReq id=0x5 "User request"]
Sep  8 18:52:19 Vigor2750 local4.info pppd[4686]: Terminating on signal 15
Sep  8 18:52:20 Vigor2750 local4.notice root: [IP-DOWN] IFACE=ppp0 TTY=eth1.101 SPEED=0 LOCAL=86.168.126.191 REMOTE=217.32.145.232 IPPARAM=wan
Sep  8 18:52:20 Vigor2750 local4.notice root: [IP-DOWN]revert uci network state in ip-down...
Sep  8 18:52:20 Vigor2750 local4.info pppd[4686]: Terminating on signal 15
Sep  8 18:52:20 Vigor2750 local4.notice ifdown: ifdown kill all pppd...
Sep  8 18:52:22 Vigor2750 local4.debug pppd[4686]: Script /etc/ppp/ip-down finished (pid 22150), status = 0x1
Sep  8 18:52:27 Vigor2750 user.notice root: udp-broadcast-relay not start: can't find interface ...
Sep  8 18:52:27 Vigor2750 local4.debug pppd[4686]: sent [LCP TermReq id=0x6 "User request"]
Sep  8 18:52:48 Vigor2750 local4.notice root: [WAN Check] check default route failed:(0), revert WAN state and ifup wan...
Sep  8 18:52:48 Vigor2750 local4.notice root: ********** ifup wan
Sep  8 18:52:48 Vigor2750 local4.notice root: ========== ifdown wan
Sep  8 18:52:50 Vigor2750 local4.info pppd[23459]: Plugin rp-pppoe.so loaded.
Sep  8 18:52:50 Vigor2750 local4.notice pppd[23462]: pppd 2.4.4 started by root, uid 0
Sep  8 18:53:04 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPINFORM(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1
Sep  8 18:53:04 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPACK(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1 ******-PC
Sep  8 18:53:05 Vigor2750 local4.warn pppd[23462]: Timeout waiting for PADO packets
Sep  8 18:53:06 Vigor2750 local4.err pppd[23462]: Unable to complete PPPoE Discovery
Sep  8 18:53:20 Vigor2750 local4.notice root: [WAN Check] check default route failed:(0), revert WAN state and ifup wan...
Sep  8 18:53:20 Vigor2750 local4.notice root: ********** ifup wan
Sep  8 18:53:20 Vigor2750 local4.notice root: ========== ifdown wan
Sep  8 18:53:20 Vigor2750 local4.info pppd[23462]: Terminating on signal 15
Sep  8 18:53:20 Vigor2750 local4.notice pppd[23462]: Remove pidfiles  /var/run/ppp-wan.pid
Sep  8 18:53:20 Vigor2750 local4.info pppd[23462]: Exit.
Sep  8 18:53:22 Vigor2750 local4.info pppd[24845]: Plugin rp-pppoe.so loaded.
Sep  8 18:53:22 Vigor2750 local4.notice pppd[24846]: pppd 2.4.4 started by root, uid 0
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: PADS: Service-Name: ''
Sep  8 18:53:22 Vigor2750 local4.info pppd[24846]: PPP session is 2359
Sep  8 18:53:22 Vigor2750 local4.warn pppd[24846]: hnat_patch_fn /tmp/pppoe.info/eth1.101
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: using channel 3
Sep  8 18:53:22 Vigor2750 local4.info pppd[24846]: Using interface ppp0
Sep  8 18:53:22 Vigor2750 local4.notice pppd[24846]: Connect: ppp0 <--> eth1.101
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: sent [LCP ConfReq id=0x1 <mru 1442> <magic 0x757d122c>]
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: rcvd [LCP ConfReq id=0xc9 <mru 1492> <auth chap MD5> <magic 0x3d2c30b1>]
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: sent [LCP ConfAck id=0xc9 <mru 1492> <auth chap MD5> <magic 0x3d2c30b1>]
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: rcvd [LCP ConfAck id=0x1 <mru 1442> <magic 0x757d122c>]
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: sent [LCP EchoReq id=0x0 magic=0x757d122c]
Sep  8 18:53:22 Vigor2750 local4.debug pppd[24846]: rcvd [LCP EchoRep id=0x0 magic=0x3d2c30b1]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [CHAP Challenge id=0x1 <e7c45158e9d315ce1ffbbdc8ae627f64>, name = "bras-red9.l-nws"]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [CHAP Response id=0x1 <e4a72ecb87f7f7d3964372eb0b9da6f4>, name = "bthomehub@btbroadband.com"]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [CHAP Success id=0x1 "CHAP authentication success, unit 10450"]
Sep  8 18:53:25 Vigor2750 local4.info pppd[24846]: CHAP authentication succeeded: CHAP authentication success, unit 10450
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: CHAP authentication succeeded
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: peer from calling number 00:30:88:00:00:03 authorized
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [CCP ConfReq id=0x1 <mppe -H -M -S -L -D +C>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [IPV6CP ConfReq id=0x1 <addr fe80::e1b0:0792:ff06:ba3d>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [IPCP ConfReq id=0xfb <addr 217.32.145.232>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [IPCP ConfAck id=0xfb <addr 217.32.145.232>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [LCP ProtRej id=0xca 80 fd 01 01 00 0a 12 06 00 00 00 01]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: Protocol-Reject for 'Compression Control Protocol' (0x80fd) received
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [LCP ProtRej id=0xcb 80 57 01 01 00 0e 01 0a e1 b0 07 92 ff 06 ba 3d]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: Protocol-Reject for 'IPv6 Control Protovol' (0x8057) received
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [IPCP ConfNak id=0x1 <addr 86.147.224.248> <ms-dns1 213.120.234.10> <ms-dns3 62.6.40.178>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: sent [IPCP ConfReq id=0x2 <addr 86.147.224.248> <ms-dns1 213.120.234.10> <ms-dns3 62.6.40.178>]
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: rcvd [IPCP ConfAck id=0x2 <addr 86.147.224.248> <ms-dns1 213.120.234.10> <ms-dns3 62.6.40.178>]
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: local  IP address 86.147.224.248
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: remote IP address 217.32.145.232
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: primary   DNS address 213.120.234.10
Sep  8 18:53:25 Vigor2750 local4.notice pppd[24846]: secondary DNS address 62.6.40.178
Sep  8 18:53:25 Vigor2750 daemon.info dnsmasq[2078]: reading /tmp/resolv.conf.auto
Sep  8 18:53:25 Vigor2750 daemon.info dnsmasq[2078]: using nameserver 62.6.40.178#53
Sep  8 18:53:25 Vigor2750 daemon.info dnsmasq[2078]: using nameserver 213.120.234.10#53
Sep  8 18:53:25 Vigor2750 daemon.info dnsmasq[2078]: using local addresses only for domain lan
Sep  8 18:53:25 Vigor2750 local4.debug pppd[24846]: Script /etc/ppp/ip-up started (pid 25007)
Sep  8 18:53:25 Vigor2750 local4.notice root: [IP-UP] IFACE=ppp0 TTY=eth1.101 SPEED=0 LOCAL=86.147.224.248 REMOTE=217.32.145.232 IPPARAM=wan
Sep  8 18:53:26 Vigor2750 user.notice firewall: Restart user's custom iptables rules
Sep  8 18:53:31 Vigor2750 user.notice root: udp-broadcast-relay not start: can't find interface ...
Sep  8 18:53:32 Vigor2750 local4.notice root: [addif] interface wan: ppp0 exist.
Sep  8 18:53:32 Vigor2750 user.notice root: adding ppp0 to firewall zone wan
Sep  8 18:53:34 Vigor2750 user.notice miniupnpd: removing firewall rules for ppp0 from zone wan
Sep  8 18:53:36 Vigor2750 user.notice miniupnpd: adding firewall rules for ppp0 to zone wan
Sep  8 18:53:42 Vigor2750 daemon.err ipsec_setup: ...Openswan IPsec stopped
Sep  8 18:53:42 Vigor2750 daemon.err ipsec_setup: Stopping Openswan IPsec...
Sep  8 18:53:42 Vigor2750 daemon.err ipsec_setup: stop ordered, but IPsec appear to be stopped already!
Sep  8 18:53:42 Vigor2750 daemon.err ipsec_setup: doing cleanup anyway...
Sep  8 18:53:44 Vigor2750 local7.err syslog: Required parameters missing, make sure that username and password are given
Sep  8 18:53:49 Vigor2750 local4.debug pppd[24846]: Script /etc/ppp/ip-up finished (pid 25007), status = 0x0
Sep  8 18:53:54 Vigor2750 local4.notice root: [WAN Check]wan just up ......skip check_pppwan
Sep  8 18:53:54 Vigor2750 user.notice root: udp-broadcast-relay not start: can't find interface ...
Sep  8 18:54:06 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPINFORM(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1
Sep  8 18:54:06 Vigor2750 daemon.info dnsmasq-dhcp[2078]: DHCPACK(br-lan) 192.168.1.102 f4:6d:04:36:c5:c1 *****-PC
Sep  8 18:54:27 Vigor2750 user.notice root: [WAN] ifdown all wan...
Sep  8 18:54:27 Vigor2750 local4.notice root: ========== ifdown voipwan
Sep  8 18:54:28 Vigor2750 local4.notice root: ========== ifdown iptvwan
Sep  8 18:54:29 Vigor2750 local4.notice root: ========== ifdown mngtwan
Sep  8 18:54:29 Vigor2750 local4.notice root: ========== ifdown wan
Sep  8 18:54:30 Vigor2750 local4.info pppd[24846]: Terminating on signal 15
Sep  8 18:54:30 Vigor2750 local4.info pppd[24846]: Connect time 1.1 minutes.
Sep  8 18:54:30 Vigor2750 local4.info pppd[24846]: Sent 87740 bytes, received 79316 bytes.
Sep  8 18:54:30 Vigor2750 local4.debug pppd[24846]: Script /etc/ppp/ip-down started (pid 27924)
Sep  8 18:54:30 Vigor2750 local4.debug pppd[24846]: sent [LCP TermReq id=0x2 "User request"]
Sep  8 18:54:30 Vigor2750 local4.notice root: [IP-DOWN] IFACE=ppp0 TTY=eth1.101 SPEED=0 LOCAL=86.147.224.248 REMOTE=217.32.145.232 IPPARAM=wan
Sep  8 18:54:30 Vigor2750 local4.notice root: [IP-DOWN]revert uci network state in ip-down...
Sep  8 18:54:31 Vigor2750 local4.info pppd[24846]: Terminating on signal 15
Sep  8 18:54:31 Vigor2750 local4.notice ifdown: ifdown kill all pppd...
Sep  8 18:54:31 Vigor2750 local4.notice pppd[24846]: Modem hangup
Sep  8 18:54:31 Vigor2750 local4.notice pppd[24846]: Connection terminated.
Sep  8 18:54:31 Vigor2750 local4.debug pppd[24846]: Waiting for 1 child processes...
Sep  8 18:54:31 Vigor2750 local4.debug pppd[24846]:   script /etc/ppp/ip-down, pid 27924
Sep  8 18:54:33 Vigor2750 user.notice root: stopping ntpclient
Sep  8 18:54:33 Vigor2750 local4.debug pppd[24846]: Script /etc/ppp/ip-down finished (pid 27924), status = 0x1
Sep  8 18:54:38 Vigor2750 user.notice root: udp-broadcast-relay not start: can't find interface ...
Sep  8 18:54:38 Vigor2750 local4.notice pppd[24846]: Remove pidfiles /var/run/ppp0.pid /var/run/ppp-wan.pid
Sep  8 18:54:38 Vigor2750 local4.info pppd[24846]: Exit.
24 REPLIES 24
LJ50
Message 2 of 25
Re: Draytek Vigor 2750 / Infinity connection problems
So, to add to this. Somewhat bizarrely (to me at least) if I remove the PPPOE details and leave the Draytek, then the VDSL connection and status is absolutely rock solid. Not a single "cycle" of idle, handshake, training, showtime. Just uninterrupted "Showtime" and solid line status. SNR upstream varies in a narrow range of 59 (0.1 db) to 61 and the downstream sticks at 62. UP Speed of 4,972 and Down Speed of 24,543. Been absolutely static for the past 15 mins.
This would imply to me that there is something at the end of the attempt to connect via PPPOE that is actively causing the disconnect. But I have no idea what, or how to resolve it.
Distinguished Guru
Message 3 of 25
It seems to be a common problem http://community.bt.com/t5/BT-Infinity/Draytek-Vigor-2750n-Connection-Issues/td-p/355021/page/17
If not, I'll try again 🙂
LJ50
Message 4 of 25
I've been through that thread already and have followed every tip in it. No luck (in fairness, that thread is a number of different issues people have had, all in one place).
I am far from being an expert, but it simply does not make sense to me that the router that was solid as a rock at my old house, is now being "kicked off" the Infinity connection.
Distinguished Guru
Message 5 of 25
Does your PPPOE setup include a password?
LJ50
Message 6 of 25
Yes.
Initially of course it was just whatever I had put in there 18 months ago (a "." I think), but when I went through the process of factory resetting, etc. I have tried ".", a space, "PW", "1234" and "12345" all of which users on here have used and found to be working. Same issue every time.
The log file suggestions CHAPS authentication works, but then the termination starts again.
ironman123
Recognised Expert
Message 7 of 25
Did you remember to set the  Multi-VLAN setting to 101 in the 2750n`s settings.?
Also on the WAN page you should use the "always on" choice,it should be ok but worth a check.
And BTW,I use the same Draytek combo and use my .btinternet.com email address for the User ID also my email PW for the VDSL logon details.
LJ50
Message 8 of 25
Thanks both.
Yes, 101 absolutely in the ID field within the Multi-VLAN area, as it was before when it was working.
Have set to "Always on", again as was at my previous home when the Draytek was working.
I've tried bthomehub@btinternet.com (as it was before when it was working), I've tried bthomehub@btbroadband.com and I've tried my firstname.surname@btinternet.com username and password (that does allow me to log in to my email so I know the details are correct).
Nothing....
Literally the only thing that has change is the line I am connected to after I've moved house.
ironman123
Recognised Expert
Message 9 of 25
A long shot,but what firmware version do you use.?
I use v1.5.3.
There is one more thing that might not matter,but when you reset the draytek,the Time settings need updating,it sometimes reverts to 1970.
BTW did you make a backup of your config file before the move,if so you could try reloading it back in.?
LJ50
Message 10 of 25
Thanks again ironman.
Initially, I was on 1.5.3 as I had been previously (maybe 3-4 months) but no luck. Reverted to 1.5.2 which I'd used for about a year. No luck. Even tried the beta of 1.5.2 which I still had. Nope
Sync'd up the time using the browser. Nothing. During the all too brief connections the time also syncs with the nntp server (see the log above). Again, inevitable termination regardless.
Have tried using the config file I saved before I updated to 1.5.3. Have tried resetting to factory defaults.
All to no avail.
I can't help but think its something purely on the BT end. Everything is right on my side, everything has worked before now. But suddenly I can't stay connected.
