qwerty56
Message 1 of 9
Drop in Speed since End Of Feb 2019
Hi speed tests from thinkbroadband below. ok up to 20 feb then a drop off when tested 10 march
router stats taken 10 march
anybody able to shed some light on it please
8 REPLIES 8
Message 2 of 9
Re: Drop in Speed since End Of Feb 2019
Enter your phone number and post results remember delete number and leave exchange and cab number.  https://www.btwholesale.com/includes/adsl/main.html
It could as simple as crosstalk with more people on your cabinet. Your connection speed is virtually at attainable with noise margin about normal 6db
qwerty56
Message 3 of 9
Hi imjolly thanks for your response
the issue started when the net went down whilst i was using it but the blue light on hub was still lit?
event log
Message 4 of 9
were you using a wifi device?
dslchecker results?
qwerty56
Message 5 of 9
qwerty56
Message 6 of 9
pc connected via ethernet but wifi devises are connected
Message 7 of 9
from the checker results you are within your estimated range and with 8 days connection appears to be stable so can't see BT doing anything to help
you are on ECI cab so like me there is currently no boost from G.INP
qwerty56
Message 8 of 9
Hi imjolly
thanks for your imput i can't see BT helping either that's why i thought i would try the forums to see if anyone could throw  some light on it
thanks
Message 9 of 9
as I said more likely to be crosstalk from more people on cab  your conenction speed is virtually at attainable with normal 6db noise margin
