pippincp
Sage
Message 11 of 22
Re: Drop in download speed after fault
Having seen your hub stats I would think so.
mikrt
Message 12 of 22
Fingers crossed 😊
mikrt
Message 13 of 22
Well after the assistance of a mod, I now understand after line speed has now settled @ 59Mbps (used to be consistant 77 - 79Mbps), that's all I'm going to get.
The thought is that there's been some work somewhere, probably in a cabinet, to supply more properties, and that the exchange to home speed I was getting is now being shared.
Not sure though why my BB hub is resarting itself every couple of days though, current uptime is just over 14 hours, and I have never once initiated a restart or turned off the hub. Every few days when I wake up my PC, there's BB down message from BT, and/or the hub will be flashing red. Then I check the Hub technical log and see it's been off.
Thanks all for your input 😍
pippincp
Sage
Message 14 of 22
Could you post your hub stats again?
mikrt
Message 15 of 22
pippincp
Sage
Message 16 of 22
Wellits not affecting your speed, you are syncing at 70Mb.
mikrt
Message 17 of 22
Thanks for helping @pippincp   I did see that, but running speed tests, I get different results.
mikrt
Message 18 of 22
pippincp
Sage
Message 19 of 22
Make sure there's nothing running in the background, especially if you have a Mac or iPhone connected.
mikrt
Message 20 of 22
I have done. And aren't these speed readings to the hub? So anything else would be included? If you see what I mean.
The PC I'm using for these is wired 2 feet from hub.
