Message 11 of 27
Re: Drop in speed FTTC :(
You are way above your handback threshold speed and only just short of maximum speed, nobody is going to do anything with those sort of figures.
Sage
Message 12 of 27
But wait @licquorice  do you not realise how so much can be done with those 6mbps??? It would save hours of downloading!
Message 13 of 27
Message 14 of 27
It is more than 6mbps more like 13 mbps because the transmission high. I guess that 13mbps can be sold off as a standard connection to someone else more profit to BT.  Just with the sync rate at 74 and then my ip profile being another 10% lower.
Message 15 of 27
The drop in connection speed is only 6mb - max possible 80 and current speed 74mb
as already said with that speed well within range BT are not going to be interested
Message 16 of 27
After 25 days of no drops or anything and my connection decides to decline further down
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANLink up85661524900101:00:11:04
LAN 1100M/Full10830534576554751900111442703:19:36:36
DSL LinkDownstreamUpstream
Connection Speed71.93 Mbps20.00 Mbps
Line Attenuation18.10 dB21.90 dB
Noise Margin6.10 dB7.40 dB
Something is not right but if it keeps on lowering and goes below 71 then BT will have to do something as my minimum guaranteed sync rate is 71. so it is getting very close. My point of sale was also quoted 77-80 for the downloads I am getting 56. So that estimate is way off.
Message 17 of 27
in BT letters the use of the word 'download' is clarified in T&C and is actually your connection speed not your download/thoughput speed which is the 56mb you quote.
I agree though that the way BT refer to download speed can be taken as throughput hence why clarified in T&C as connection speed
Message 18 of 27
The way I understood it is that the modem receives a connection speed that is the minimum guaranteed speed. As far as the downloads go that is decided by Open Reach and what ever limit they have put in place on your IP Profile against your connection rate.
So if the connection rate drops below my minimum guaranteed then BT can either be interested in my issue and get my speeds back to the way they were or I can leave the contract with our further hassle. Not that it really solves any under lying issue of why my connection is slowly declining.
Message 19 of 27
If your connection speed is dropping there is clearly a line fault,  until that is fixed there is no point in a DLM reset as it will just drop again afterwards. But until your speed drops below the guaranteed speed, BT won't be interested.
Message 20 of 27
The handback speed is based on your connection speed not the speed at which you download so until your speed drops below handback then BT may not take any action
if your connection is stable then unusual for a reset and drop in connection speed
