Message 1 of 8
EE Router get full speed non ee router dont Full fibre FTTP
I have been a BT customer for many years, using my Netgear Nighthawk at full speed until recently.
However, I have since been converted over to EE — not liking that decision one bit. My Netgear router has dwindled in speed. I was using the old BT logins for PPPoE — are they still correct?
Why should my speed basically be crippled using the same router I have used for years with no issues up until a few months ago? I checked with EE, and the package is the same full 1GB FTTP
I was using the old  method of connecting my netgear night hawk what gives so frustrating.
Both laptops connected etherenet report speeds of less than 300mb on netgear while ees hub reports 900 what gives
Username [email protected] and Password BT.
7 REPLIES 7
Message 2 of 8
Re: EE Router get full speed non ee router dont Full fibre FTTP
The BT hub login and password should work on 3rd party router on EE
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
Message 3 of 8
I'm using my own router, pfsense based, with no issues on 900Mbps and get full speed.
In fact on the day I migrated from BT to EE the IP number didn't change or the connection drop so just the same service.
Message 4 of 8
Can you explain what you mean by that? What is that "old  method"?
What Netgear router is this? How is it set up? And how is it connected to the Internet?
Whenever you change your service you may have to reset the router to eliminate any old settings and set it up from scratch for the new service.
If you are using the Nighthawk app to set up the router, a manual approach with the a web browser and the graphical user interface (GUI) gives you more control.
Message 5 of 8
Why has someone marked something as a resoluton as not
I actually had to go and buy a new router my old nighthawk internals was the issue of the speed drop I got a new Nighthawk RS300 and back to full speeds again. @imjolly why did someone select a marked as answer when not me that shouldnt be allowed.
Message 6 of 8
How old was the Nighthawk?
A lot of the old generation of routers were never designed with FTTP in mind.  Even though they had gigabit ports, the firewall throughput was limited to 350 - 450 Mb/s, depending on make/model etc.  That was perfectly adaquate for a network with internal speeds of gigabit and an FTTC connection of 80Mb/s but found wanting for an FTTP connection, of course.
A look at the manufacturer's specs will tell you.
Message 7 of 8
It was hitting 900mb only up till last few weeks ago.
Got the EE router and it work fine full speed.
So was def the old nighthawk internals failing.
So was just end of life of the product.
But liked the Night hawk brand so got ther300 so good upgrade its copes with 2.5GB total bandwidth thru the ports @WSH
Message 8 of 8
There are very few things on a router that can fail in the manner described. If devices suddenly start connecting over 2.4GHz when they'd previously connected at 5GHz, you might see a drop from 1Gbps to 100Mbps on a wired connection to the router or from 866Mbps to 300, 150, or 75Mbps on Wifi.  It's usually one of those scenarios, or total failure!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
