Message 1 of 3
Ee plus router on bt full fibre
Hi would the ee plus router be plug and play replacement for the bt smart hub ? I’m on full fibre 900mb I have the opportunity to have one for pennys
2 REPLIES 2
Message 2 of 3
Re: Ee plus router on bt full fibre
Yes, it uses the same credentials as BT hubs
Message 3 of 3
Great thanks for the reply !
