Message 1 of 9
Eero 6 dual-band mesh Wi-Fi 6 extender
Good day all,
I have just changed my provider from Ogi full fibre  to BT full fibre and have 2 Eero 6 dual-band mesh Wi-Fi 6 extenders which I used with my previous provider , am I able to use these with BT full fibre please?
Thanks in advance
8 REPLIES 8
Message 2 of 9
Re: Eero 6 dual-band mesh Wi-Fi 6 extender
I can think of no reason why not - as long as you don't require a telephone "landline" using digital voice. In that case you have to use a BT Smarthub 2 or equivalent EE router to get its telephone socket.
Message 3 of 9
Message 4 of 9
Thanks for the speedy reply, I have no telephone "landline". how would I go about ssetting this up please?
Kind Regards
Message 5 of 9
In exactly the same way as you did with your previous supplier.
Presumably you just have extenders rather than an Eero router as well as extenders.
Message 6 of 9
I just have the extenders and a BT router when I plugged the extenders in with my old provider it automatically picked them up,with BT they dont
Message 7 of 9
Presumably they still expect to see the old router. Factory reset them and set them up afresh.
Message 8 of 9
Reset extenders and the BT smart hub 2 don't recognise them,thanks anyway
Message 9 of 9
I'm not familiar with the Eero devices, but the hub won't connect to them, they connect to the hub. What do the setup instructions say?
