Message 1 of 3
Equipment not delivered, question about using current kit
Hi I have an installation tomorrow(FTTP) and still don't have my equipment.
I am currently using a TP Link AC2100 for my broadband and I was wondering if this will be compatible with the broadband till my hub arrives? I am aware digital voice won't work but at least I would be able to use the internet. It has a port on the back labelled as WAN.
2 REPLIES 2
Message 2 of 3
Re: Equipment not delivered, question about using current kit
Yes if you configure it to use PPPoE over the WAN port and user/pass below you should be ok until the SH2 arrives.
User: [email protected] / Pass: bt
Message 3 of 3
Excellent thank you. I think I have it setup like that currently (FTTC)
