wy14
Message 1 of 6
Estimated speed lower than actual
Hi everyone, I’ve got a bit of a strange issue.
I’m currently receiving fibre broadband (approx 35mb). I’m approaching the end of the minimum term with BT so started looking around. When I review available packages, all the estimates started returning between 6-13mb.
So I checked the DSL Checker and that showed a similar result. I’m on mobile at the moment so will post a full result when I’m home, but for now it shows VDSL Range A 13.7, Impacted 13.7. Handback threshold 5.9.
I get similar results when I look at both BT and other ISP packages.
I think it’s an issue with the openreach database. I have had a couple of faults lately so could that have caused the figures to go a little skew?
Tried speaking to BT through online chat, but they didn’t really get what I was saying and just ended the chat.
Anyway, does anyone know how I can get the figures corrected to be more in line with the actual? It’s preventing me from signing up to a new deal.
Cheers
5 REPLIES 5
wy14
Message 2 of 6
Re: Estimated speed lower than actual
heres the line stats from DSL Checker
  HighLow High Low
VDSL Range A (Clean)13.77.81.20.85.9AvailableAvailable--
VDSL Range B (Impacted)13.77.11.20.65.2AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 3--2.5 to 6.5Available----
ADSL MaxUp to 3--2 to 5.5Available----
WBC Fixed Rate1----Available----
Max Observed Downstream Speed (Mbps)36.4
Max Upstream Observed Speed (Mbps)8.19
Observed Date2019-04-26
wy14
Message 3 of 6
and the sync speed from the router stats.
 Downstream sync speed: 37.28 Mbps
Sage
Sage
Message 4 of 6
You are not the only one repoting this, hopefully it will be corrected over the next couple of days.
wy14
Message 5 of 6
Ok. Thanks for the info.
wy14
Message 6 of 6
Still experiencing this issue.
Does anyone one know how I can sort this?
