andrewdavies509
Message 1 of 3
Ethernet causes temporary error: "The default gateway is not available"
Every 5 or so minutes, the connection of all Ethernet devices on my network drops out, with the Troubleshooter fixing it with the message "The default gateway is not available". This has caused much frustration as the only way to fix it is by using the Troubleshooter or waiting it out.
I have already set the default gateway to the correct value(192.168.1.254, if I am not mistaken) yet no result.
Any help would be great.
2 REPLIES 2
licquorice
Message 2 of 3
Re: Ethernet causes temporary error: "The default gateway is not available"
Try a factory reset of the hub by pressing the recessed button for 20 seconds until the lights flash.
I have deleted your duplicate post.
andrewdavies509
Message 3 of 3
No luck! However, if it is of any use, Google Chrome gives the error message "DNS_PROBE_FINISHED_NO_INTERNET".
