Message 1 of 23
Extremely slow download speed
I've been experiencing some really slow speeds over the past week.
I should be getting 52Mbps download and 10Mbps upload, but instead I'm getting around 5-10Mbps download and 18Mbps upload. (even with wired connection).
I am really disappointed as it had been working fine until last week.
I called BT and they first, after a series of speed tests, identified a fault in the network, and sent someone to fix it.
However the speed did not improve, I called again and this time they sent an engineer to my house and tested the speed from
the telephone socket with his modem. The speed the modem is getting is 80Mbps download and 20Mbps download. He told me to wait and get in touch with BT again and they might ask me to configure something with my router...
I tried calling BT again and after an 1-hour gruelling speed tests they seemingly identified another network fault... but if that is the case how would the engineer be getting perfect speed on his modem? I'm really confused. I don't know if it has anything to do with the router.
The BT Wholesale test suggests that I'm getting 30Mbps DL/19Mbps UL, which is so far from reality...
Please help I am really out of my wits now. 😞
22 REPLIES 22
Message 2 of 23
Re: Extremely slow download speed
Welcome to this user forum.
 In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Which BT home hub do you have?
Please could you post the results from the BT Wholesale speed checker, including the further diagnostics.
http://www.speedtest.btwholesale.com/
Message 3 of 23
Exchange MAIDA VALE is served by Cabinet 52
Message 4 of 23
which exchange and cabinet?
Message 5 of 23
on Exchange MAIDA VALE is served by Cabinet 52
Message 6 of 23
I have asked mods to check to see if your problem is congestion
Message 7 of 23
Thank you.
Message 8 of 23
A lot of errors on your line can also cause slow download speed. Was the 17070 quiet line test ok?
Moderator
Moderator
Message 9 of 23
@dan013157 Welcome to the community and thanks for posting, I'm sorry to see you're having problems with your connection.  I've checked the congestion report and there are no issues reported for the Maida Vale exchange area.
Are you seeing the issue at all times or only during the evening/weekends?
Message 10 of 23
did you try quiet line test as @Keith_Beddoe asked?
