Message 1 of 5
Extremely slow fibre broadband
I have normally 20 mbps plus but every so often it drops to an unacceptably low 4mbps.
My immediate next door neighbour has a consistent 24mbps,  I would expect mine to be the same.
Could you please investigate this fluctuation, thank you in anticipation
4 REPLIES 4
Message 2 of 5
Re: Extremely slow fibre broadband
This is as it says on joining a community forum where customers help customers  your post does not go to BT
in order for forum members to help you can you post hub stats. If hh6 then advanced settings then technical log information
enter your phone number and post results remember delete number.   http://www.dslchecker.bt.com/
Check for line noise. Dial 17070 option 2 should be silent and best with corded phone
Message 3 of 5
Thanks for reply Distinguished Sage, no noise on line, hh5 is it the same for getting the info?
Sage
Sage
Message 4 of 5
HH5 Troubleshooting/helpdesk.
Moderator
Moderator
Message 5 of 5
Hi @grumpyfrombroadoak and welcome to the community.
I'm sorry you're having problems with the connection speeds. If you can post the details requested by @imjolly I'm sure we'll be able to help.
Cheers
David
