@jackftfc99 wrote:
We are not using any filters. Everything seems to be connected fine
There are three possibilities.
The socket is faulty.
The home hub is faulty.
The port in the cabinet is faulty
Lets prove the socket first, you will need a microfilter for this. Ignore the fact that you have a filtered faceplate, the bit behind is the same on both.
If you can please connect things up as shown here NTE 5C - testing from test socket
See if the connection speed on the home hub increases.
@jackftfc99 wrote:
This helped a lot, the download speed is now 27mbps, this is still lower than our minimum guaranteed speed though.
What connection speed is showing on the home hub 6, use the link that gave you the connection results.
This one, if you have lost it.
Please use this link to display the Smart hub (HH6) connection information
Are there any wires connected to the extension block NTE5C terminals for extension wiring
It may have a clear cover on it.
I think that filtered faceplate is faulty.
No there are no wires in the extension block. Here are the results
BT Hub 6A
+084316+NQ74568761
SG4B1000B316
16-Jan-2018
1.0
1.64.0
0 Days, 0 Hours 9 Minutes 41 Seconds
7.20 Mbps / 30.00 Mbps
10898 / 46720
6.5 dB / 9.4 dB
17.2 dB
0/38
G_993_2_ANNEX_B
Fast Path
4126 MB Uploaded / 4453 MB Downloaded
bthomehub@btbroadband.com
Active
BTHub6-Q92C
Smart (Channel 1)
BTHub6-Q92C
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
7C:26:64:FC:07:EB
9.2.0
So that filtered faceplate is faulty.
Your connection speed is now 30Mbs , but the maximum possible at the moment, is 46Mbs. That is still below the minimum, but it may improve,
If your service was activated on the 16th, then you are going to have to leave it now until the 26th before it can be investigated.
The speed may improve over that time, but there is still the issue with the faulty faceplate.
What I would like you to do, is to leave it connected to that test socket, do not disconnect or restart the home hub.
Check the connection speed again on the 26th, if it has not improved, then a free visit can be arranged, to investigate the problem, and to change that faulty faceplate.
See Complaints about slow broadband speed
that page tells you what the process is.
Please update this thread, as a visit can be arranged by one of the moderators, if the speed does not improve.
I have passed some information and a suggestion to one of the moderators, as I think this is a faulty installation.
@jackftfc99 wrote:
That's brilliant, thanks for all the help
No problem, that is what this user forum is for. At least you are now getting a decent speed.
Please keep this thread updated until the issue has been fully resolved.
