Paulkyle67
Message 1 of 2
FAST TO INTERLEAVING
Hi all
I am experiencing lag on my online gaming. I have done tests on my line and all good. Speeds stable at 53meg. My setting in my broadband are at "Fast" and was wondering if anyone could help to change this to "interleaving"
I get the error message on my gaming that there is an issue. I have tried different hubs, ( only smart hubs) will try a 5 today. Hut after numerous calls to BT they cannot help me with it. I know there is no line fault and my set up is as it should be. No drops in sync either. I use a wired connection also.
Please help as it's doing my head in
1 REPLY 1
h3x1e
Expert
Message 2 of 2
Re: FAST TO INTERLEAVING
DLM will kick your line onto Interleaving if it sees enough errors over a certain period.
If your line isnt erroring to the DLMs threshold then you'll stay on the Fast Path, also if you're looking at the BT Home Hub stats page, the "Fast" Latancy Type is refering to your Upload and not Download, it's quite possible you're already Interleaved on the Downstream at prolly 8ms.
Interleaving will increase your ping in games btw.
