Message 1 of 6
FF Installation Outside Work
We had full fibre installed today and I didn't see the outside until after the workmen had left.
My question is, should it have been left open like that?
5 REPLIES 5
Message 2 of 6
Re: FF Installation Outside Work
If that conduit previously had a weather cap over it, then it should have been put back. If the cap is in the trash then the quick fix could be a little DIY, but yes, the contractors should have done this, or at least brought it to your attention!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 6
I suspect what happened is the square cover that was covering the copper cable going into the house, you can see its outline on the image  ( BT cover 101a if interested and wanted to order one online yourself ) was brittle due to years of UV exposure and in trying to get the optical cable past it , it disintegrated, and it’s not necessarily something an installer, especially a contractor would have on their vehicle….
TBH , that’s not what I’d be unhappy with , I’d be more disappointed that the new CSP (the new grey box ) wasn’t fitted directly on top of the grey capping , a neater job and would have covered the copper cable as well .
Just to be clear , is this an Openreach installation and BT are your ISP , if the CSP is Openreach it’s presumably a relatively new design.
Message 4 of 6
Yes I expected CSP to be directly at top which would have covered things.
Job was done by Circet, subcontracted from Openreach on behalf of BT/EE.
Message 5 of 6
Message 6 of 6
That’s Top Notch. 👍
