ChrisJT
Message 1 of 5
FTTC Broadband IP Profile
My daughter and I both have fibre broadband and are connected to the same Cabinet. My daughter lives 800 metres from the cabinet and I live on the same street just 100 metres further away i.e I am 900 metres from the cabinet.
My line has a speed of 17.7 to 23.7 Mbs and I typically get 18.5 Mbs. My daughters line has a speed of 46 to 60.8 Mbs with a guaranteed minimum speed of 35 Mbs.
I have spoken to BT retail and BT Business who have both told me that my maximum speed is 19.3 Mbs. Other ISP's have quoted the same minimum and maximum figures i.e around 18 Mbs
Why am I unable to get a similar speed to my daughter, surely the speed should not drop off by 19Mbs for just an extra 100m of copper wire
4 REPLIES 4
Message 2 of 5
Re: FTTC Broadband IP Profile
In order to find out what services and speed range yo should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
Could you please post the results from the BT Wholesale speed checker, including the further diagnostics.
Why is BT Business involved, are you a business user?
Message 3 of 5
sounds like your line is routed differently to your daughter's phone lines rarely follow straight lines
ChrisJT
Message 4 of 5
Thanks, here is the speed test
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 18.64 Mbps
0 Mbps19.33 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 18.64 Mbps
 For your connection, the acceptable range of speedsis 13.53 Mbps-19.33 Mbps .
 Additional Information:
 IP Profile for your line is - 19.33 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 3.08 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 3.08Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
 Here is info from hub manager
1. Product name:BT Business Hub
2. Serial number:+076399+NQ50629629
3. Firmware version:Software version 4.7.5.1.83.8.230 (Type A) Last updated 16/07/16
4. Board version:BT Hub 5A
5. DSL uptime:3 days, 18:25:44
6. Data rate:3381 / 19973
7. Maximum data rate:3363 / 21530
8. Noise margin:6.0 / 8.1
9. Line attenuation:35.0 / 27.8
10. Signal attenuation:35.1 / 24.2
11. Data sent/received:657.5 MB / 4.3 GB
12. Broadband username:
I am with BT Business but am thinking of switching to get a better price
Message 5 of 5
As you are a BT Business user we cannot help you here I suggest you try the Business forum https://business.forums.bt.com/t5/Broadband-and-internet/bd-p/Broadband
