Moderator
Moderator
Message 21 of 21
Re: FTTC DLM Reset - Odd Behaviour
Hi @Big-G  and thanks for getting back.
As @imjolly  has mentioned a slight fluctuation in the noise margin is normal. The stats you're posted confirm the problem should now be sorted.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
