Hello all.
Long time since my last broadband fault only to find the current fault reporting system to be useless. The online system took me through pointless steps and irrelevant wifi improvement steps. I don't have a wifi issue, only a downstream connection issue between the DSLAM and my property.
Phone assistance was even worse. A lady who struggled with English or just ignored my responses and wanted to know about the lights on my non-existent hub. Or grasp that my wifi was fine and was not being used for the fault finding. Or comprehend that my router is also fine and was also not used during the fault finding. She had no interest in my actual fault and after going around in circles and 'what colour light do you have' I was just cut-off, again.
Anyway, not a complicated issue:
DN21 area connected to Cab 34 - FTTC (ECI)
Normal Downstream Attainable ~ 82Mbps and Upstream ~25Mbps (cabinet reasonably close, circa 100M, all copper, direct via conduit)
So the Actual Rate is service capped at the 79.99 and 20.00Mbps limit
Downstream for the last few days has become very erratic, the Actual Rate has now been lowered by the DSLAM to between 60 to 70Mbps with the dreaded interleave now on and commensurate leap in latency. The Attainable Rate is still showing ~82Mbps. Upstream seems unaffected by the fault and remains on fast path, albeit with the Attainable Rate lowered a little but still a 20Mbps Actual Rate.
Done the usual fault finding, direct to test port (ie no phone circuit), tried a different modem and tried a direct PPPoE connection from laptop to modem (ie taking my router out of the equation). No change in results so fault is between me and the DSLAM. Given the results it looks like a DSLAM issue.
And yes, they have been working in my cabinet recently and getting g.fast up and running.
So how do I actually report a fault to someone capable of listening and resolving the issue?
Step 1 is probably a DSLAM reset from Openreach.
Nothing glaring in the frequency bins or line stats, well apart from the interleave/capped downstream report:
> v s more
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 4507 48454 (seconds)
ES : 0 3080 (seconds)
SES : 0 26 (seconds)
LOSS : 0 113 (seconds)
UAS : 34 885 (seconds)
HECError : 0 0
CRC : 0 4685
RsCorrection : 0 0
INP : 0 15 (symbols)
InterleaveDelay : 0 800 (1/100 ms)
NFEC : 255 85
RFEC : 16 16
LSYMB : 5410 21746
INTLVBLOCK : 255 85
AELEM : 0 ----
> Restarting modem ...
> v s
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 69918000 bps US Actual Rate : 20000000 bps
DS Attainable Rate : 81056888 bps US Attainable Rate : 23344020 bps
DS Path Mode : Interleave US Path Mode : Fast
DS Interleave Depth : 1019 US Interleave Depth : 1
NE Current Attenuation : 11 dB Cur SNR Margin : 5 dB
DS actual PSD : -1.-7 dB US actual PSD : -1.-6 dB
NE CRC Count : 0 FE CRC Count : 4685
NE ES Count : 0 FE ES Count : 3080
Xdsl Reset Times : 0 Xdsl Link Times : 4
ITU Version[0] : fe004452 ITU Version[1] : 41590000
VDSL Firmware Version : 05-07-09-0F-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 10 dB Far SNR Margin : 6 dB
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206
DSLAM CHIPSET VENDOR : < IFTN >
Direct to test port (phone circuit disconnected) and direct PPPoE from Mac to Modem:
> vdsl show statistics
DOWNSTREAM :
Bin SNR Gain Bi - Bin SNR Gain Bi - Bin SNR Gain Bi - Bin SNR Gain Bi
dB .1dB ts dB .1dB ts dB .1dB ts dB .1dB ts
0 0 0 0 * 1 0 0 0 * 2 0 0 0 * 3 0 0 0
4 0 0 0 * 5 49 0 0 * 6 50 0 0 * 7 51 0 0
8 51 0 0 * 9 50 0 0 * 10 50 0 0 * 11 50 0 0
12 50 0 0 * 13 50 0 0 * 14 49 0 0 * 15 49 0 0
16 48 0 0 * 17 48 0 0 * 18 47 0 0 * 19 47 0 0
20 46 0 0 * 21 46 0 0 * 22 45 0 0 * 23 45 0 0
24 45 0 0 * 25 44 0 0 * 26 44 0 0 * 27 43 0 0
28 43 0 0 * 29 42 0 0 * 30 42 0 0 * 31 41 0 0
32 41 0 0 * 33 40 0 14 * 34 39 15 15 * 35 38 -19 14
36 37 0 15 * 37 36 -19 14 * 38 35 -19 14 * 39 33 0 14
40 32 0 14 * 41 31 0 14 * 42 30 0 14 * 43 29 0 14
44 28 0 14 * 45 26 0 14 * 46 25 0 14 * 47 24 -19 14
48 24 -19 14 * 49 23 -19 14 * 50 23 -19 14 * 51 23 -19 14
52 23 0 15 * 53 23 0 15 * 54 23 -19 14 * 55 23 0 15
56 23 0 15 * 57 23 0 15 * 58 23 -19 14 * 59 23 0 15
60 23 0 15 * 61 23 0 15 * 62 23 0 15 * 63 23 0 15
64 30 0 15 * 65 39 -19 14 * 66 43 0 15 * 67 44 0 15
68 44 0 15 * 69 45 0 15 * 70 44 0 15 * 71 44 0 15
72 44 -19 14 * 73 44 -19 14 * 74 43 0 15 * 75 42 -19 14
76 41 0 15 * 77 41 -19 14 * 78 41 0 15 * 79 40 0 15
80 40 -19 14 * 81 40 0 15 * 82 41 -19 14 * 83 41 -19 14
84 41 -19 14 * 85 41 0 15 * 86 41 0 15 * 87 41 0 15
88 41 0 15 * 89 41 -19 14 * 90 41 0 15 * 91 41 0 15
92 40 0 15 * 93 40 -19 14 * 94 40 -19 14 * 95 40 -19 14
96 40 -19 14 * 97 40 -19 14 * 98 40 0 15 * 99 40 15 15
100 40 -19 14 * 101 39 -19 14 * 102 39 15 15 * 103 39 -19 14
104 39 -19 14 * 105 39 -19 14 * 106 38 -19 14 * 107 0 -19 14
108 0 -19 14 * 109 0 -19 14 * 110 0 -19 14 * 111 0 -19 14
112 0 -19 14 * 113 0 -19 14 * 114 0 -19 14 * 115 0 -19 14
116 0 -19 14 * 117 0 -19 14 * 118 0 -19 14 * 119 0 0 14
120 0 -19 14 * 121 0 -19 14 * 122 0 0 14 * 123 0 0 14
124 0 -19 14 * 125 0 -19 14 * 126 0 -19 14 * 127 0 0 14
128 0 -19 14 * 129 0 -19 14 * 130 0 -19 14 * 131 0 0 14
132 0 0 14 * 133 0 0 14 * 134 0 0 14 * 135 0 0 14
136 0 0 14 * 137 0 0 14 * 138 0 0 14 * 139 0 0 14
140 0 0 14 * 141 0 0 14 * 142 0 0 14 * 143 0 0 14
144 0 0 14 * 145 0 0 14 * 146 0 0 14 * 147 0 0 14
148 0 0 14 * 149 0 -19 13 * 150 0 -19 13 * 151 0 -19 13
152 0 -19 13 * 153 0 0 14 * 154 37 -19 13 * 155 37 -19 13
156 36 0 14 * 157 36 -19 13 * 158 35 0 14 * 159 35 -19 13
160 35 -19 13 * 161 35 -19 13 * 162 35 -19 13 * 163 35 -19 13
164 35 -19 13 * 165 35 -19 13 * 166 35 -19 13 * 167 35 -19 13
168 35 -19 13 * 169 35 -19 13 * 170 35 -19 13 * 171 35 -19 13
172 36 -19 13 * 173 35 0 13 * 174 35 -19 13 * 175 35 -19 13
176 35 0 13 * 177 35 0 13 * 178 35 0 13 * 179 35 0 13
180 35 0 13 * 181 35 0 13 * 182 35 0 13 * 183 35 0 13
184 35 0 13 * 185 35 0 13 * 186 35 0 13 * 187 35 0 13
188 35 0 13 * 189 35 0 13 * 190 35 0 13 * 191 35 0 13
192 35 0 13 * 193 35 0 13 * 194 35 0 13 * 195 34 0 13
196 34 0 13 * 197 34 0 13 * 198 34 0 13 * 199 34 0 13
200 34 0 13 * 201 34 -19 12 * 202 34 0 13 * 203 33 -19 12
204 33 -19 12 * 205 33 -19 12 * 206 33 -19 12 * 207 32 0 13
208 32 -19 12 * 209 32 -19 12 * 210 32 -19 12 * 211 32 -19 12
212 32 -19 12 * 213 32 -19 12 * 214 32 -19 12 * 215 32 -19 12
216 32 -19 12 * 217 32 -19 12 * 218 32 -19 12 * 219 32 -19 12
220 32 -19 12 * 221 32 -19 12 * 222 31 -19 12 * 223 32 -19 12
224 31 -19 12 * 225 31 -19 12 * 226 31 -19 12 * 227 31 -19 12
228 31 0 12 * 229 31 0 12 * 230 31 0 12 * 231 30 0 12
232 30 0 12 * 233 30 0 12 * 234 30 0 12 * 235 30 0 12
236 30 0 12 * 237 30 0 12 * 238 30 0 12 * 239 31 0 12
> v s
DS Actual Rate : 70387000 bps US Actual Rate : 20000000 bps
DS Attainable Rate : 81502856 bps US Attainable Rate : 23251614 bps
DS Interleave Depth : 1024 US Interleave Depth : 1
NE CRC Count : 0 FE CRC Count : 4702
NE ES Count : 0 FE ES Count : 3091
Xdsl Reset Times : 0 Xdsl Link Times : 1
Test Mode : DISABLE
> v s more
I need actual technical help and have no idea how to achieve it.
Solved! Go to Solution.
Any noise on your line? 17070 option 2. Best with corded phone.
Unless the line speed is lower than the minimum rate specified in your contract, or you are getting multiple disconnects, there is nothing that can be done.
Hi & thanks - the line speed is important no doubt, but the stability and latency are the real area of concern.
Whilst I have enjoyed a good BT FTTC service to date, shrugging off a fault and accepting it is not really acceptable. The infuriating web and phone customer service adds another irritant. It appears to drive the customer into believing they have a wifi problem. In my case the online fault checker offered to sell me a BT wifi extender and I have zero issues with my wifi.
Openreach allows ISPs to request a DLM / concern counter reset, I cannot request this myself. I am very accepting that broadband disturbances can happen when the guts of my street cabinet are pulled out whilst upgrades and testing are ongoing. These things happen.
My line speed remains at 82Mbps, it is the DLM banding and interleaving that was my first concern, followed very quickly by the abysmal online fault reporting system and the unhelpful scripted / contracted-out call centre.
I remain hopeful BT can at least try to do something. As it is Openreach will have no idea that this end user has an issue and I have not even achieved a fault number that can be tracked.
That said, if this really is the new reality in that BT will not do anything in the coming days then I guess I will have to shrug and try a different ISP.
I am just a customer, so all I can say is that BT are unlikely to investigate your complaint, as there is no actual fault as such.
You would not get a reset unless the line is performing below your contracted rate, after a fault on your line has been repaired
Unless you find an ISP who does not use the Openreach network, then you are going to be stuck with the same pair of wires, and the same equipment in the cabinet.
Thanks Keith but at the moment I am struggling to find a way to even register the fault without being stuck on a call centre script.
Speed isn't everything, stability and quality of service count too. The speed achieved when the connection drops is, well, zero.
Managed to get through the wall of no help at the overseas call centre after a few weeks of trying. A fault was begrudgingly raised and forwarded to Openreach, who acknowledged it and said they had a team in the area so would be able to check the cabinet that same day.
Within a couple of hours I was informed that it was an 'easy fix' (due to a misconfiguration after G.fast work) and that my speed and stability should return to normal.
The stability improvement was instant and the speed recovered to normal over a few days and has remain so for the last few days. I don't have quite the same margin over-and-above the capped rate as I had, but that does not impact my service and may improve with routine DSLAM tuning.
I must acknowledge that once the fault was with the actual faults team the communication, updates and the relaying of information about the fault to and from the Openreach team was excellent.
The 'front door' of BT broadband fault reporting needs a serious adjustment, but once through that painful obstacle everything was great - especially the 'live-chat' support.
DS Actual Rate : 79995000 bps US Actual Rate : 20000000 bps
I nearly got a pack of chocolate hobnobs to the Openreach guys who worked on my street cabinet in awful weather, but they pulled away just before I got there!
