Checked2013
Expert
Message 41 of 44
Re: FTTC Fibre 2 ¦ Product Speed Review.
The evidence you have posted (and since deleted, mainly because it proves you wrong) shows you are getting above 10mb upload. I have asked nicely for you to provide a speed test (which you have chosen to ignore).
My only conclusion is that you are obsessed with trying to squeeze every last byte out of your connection, even though it's not wanted or required.
I have also posted a way for you to get a faster speed if you wish that (you have ignored that to)
imjolly
Message 42 of 44
@COMPANY-PENSIONER
this thread is now pointless as you are just going round in circles and editing posts after replies to suit yourself.  good luck with your 80/16.99mb connection speed  No ISP guarantees download/upload speeds
COMPANY-PENSIONER
Message 43 of 44
I would suggest that the continuing demand for informatiom, is totally unconstructive.
I've layed out the course of action I'm pursuing, in search of the mighty 14-15Mbps Upload.
A SERIAL WIND-UP, IT IS THEN !
JohnC2
Moderator
Moderator
Message 44 of 44
Hi All, I think that this thread has now reached the point that no further value can be added and the replies are just going over old ground. I have therefore decided to lock this thread.
John
