Stewart1
Message 1 of 13
FTTC availability
Hello
I hope someone can point me in the right direction with this.
This question is raised on behalf of my father in law who is struggling to upgrade to FTTC despite a new cabinet recently being installed outside his property.
Their existing ADSL is ok but not reliable.
I know from looking at BT DSL CHECKER that other houses on the same road are connected to the new cabinet of the exchange and are capable of 80/20 FTTC.
BT really need Openreach to survey the address and confirm this is possible, I thought there was an emphasis on Openreach and service providers to get people onto super fast broadband as soon as possible and the infrastructure is now there but for a couple of spans of dropwire.
How do we sort this out?
Thanks in advance.
Stewart
12 REPLIES 12
gg30340
Message 2 of 13
Re: FTTC availability
If you use this checker it will tell what cabinet you are on and what services it can receive. Once you have removed your phone number, post a screen shot on the forum for information about what is available.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it does not show a cabinet number it will be because you are on an Exchange Only(EO) line. This means you can not get Infinity because you are not connected to a cabinet, instead you are connected directly to the exchange.
Sometime in the future Openreach may install a cabinet out side the exchange and this will allow EO lines to connect to a cabinet. This however is not high on their priority list so may take some time.
Use your phone number. If you don't have a BT number use the address checker. It is more accurate than the post code checker which can cover more than one cabinet.
CJT80
Recognised Expert
Message 3 of 13
@Stewart1wrote:
Hello
Thanks in advance.
Stewart
Hi there @Stewart1
Just to clarify, is your father with BT for his ADSL?  You mentioned the DSL Checker, could you access it again (if he's with BT use his telephone number, if not his address) and if possible copy and past the info into here? Or even better a screenshot? Note: Please remove any address or phone number before posting.
Here's my example:
Note I am not on BT so I cannot use my number.  Just want to see what is available to him.
Then we can advise better for you.
EDIT: Must work on replying faster... @gg30340 beat me to it
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Stewart1
Message 4 of 13
Stewart1
Message 5 of 13
Hello
This is where the issue lies as with the number (which is on BT) it only shows ADSL 2+ as being available, the cabinet is 2miles away from the house.
However a new cabinet has been installed literally 30m from their front door, how do we get BT to get Openreach to reroute the line through this new cabinet.
I can screenshot the BT DSL checker later but it may not be that useful.
I used to work for Openreach so have a reasonable level of knowledge, it’s about getting the right people to speak to the right people!
What is the best approach?
Stewart
imjolly
Message 6 of 13
There are numerous posts on the forum similar you yours and openreach has responded in all cases that they will not change you to a different cabinet just so you can get a faster broadband connection If you worked for openreach then maybe you know someone you can talk to but the forum cannot help you move cabinet
Stewart1
Message 7 of 13
Even when the difference is so vast?
I will have a look for some similar posts, if you could point me in the right direction I would appreciate it.
CJT80
Recognised Expert
Message 8 of 13
Stewart
It would be very useful.  Also IF OR are installing a closer cabinet who knows they may have something else in mind with the local connections.  Can anyone nearby get any Fibre?
Kind Regards
CJT80
Stewart1
Message 9 of 13
The first screenshot is father in law's line and second is an address 200m down the lane (rural Dorset)Screenshot_2018-04-01-19-41-13~02.jpg
I appreciate it is not that simple to change routes but this is to change from 1.5mbit to 40+, it will happen some time, we just want to escalate this.
The posts I have read seem different to our situation, cab 2 is 2miles away and cab15 is 30metres.
Thank you
pippincp
Message 10 of 13
If the nearby cabinet has just been installed it is possible (not guaranteed) it is an "infill" cabinet. If this is the case then lines to be migrated to it will already be decided and there is nothing a customer or ISP can do to change the decision of Openreach.
Even if the line is on the list don't hold your breath as it can take up to 3 months before even starting. As it will entail a brief loss of service to customers Openreach have to have the go ahead from all service providers.
