imjolly
Message 11 of 65
Re: FTTC connection 300 feet from cab poor downstream
can you post the new stats from the test socket  advances settings then technical log admin
stoswald
Message 12 of 65
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B1000B316
Firmware updated:
13-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 42 Minutes 35 Seconds
Data rate:
20.00 Mbps / 56.27 Mbps
Maximum data rate:
24597 / 57505
Noise margin:
15.3 dB / 6.3 dB
Line attenuation:
14.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
6180 MB Uploaded / 10000 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-TS7Q
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-TS7Q
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:4E:E7:11
Software variant:
Boot loader:
9.2.0
imjolly
Message 13 of 65
still below estimate
if you have phone sockets in other rooms have you checked that the do not have a dial tone?
stoswald
Message 14 of 65
no extensions in any other rooms in the house
imjolly
Message 15 of 65
then you need engineer visit to find cause of low speed - less than estimated  will be easier if mods help you and arrange engineer visit  they will post here
Keith_Beddoe
Message 16 of 65
@stoswaldWhat speed range did they say on you would get?
The distance from the cabinet means nothing, as the cable may not go direct to your house.
You are connecting above the handback speed at the moment.
stoswald
Message 17 of 65
59-80 mb estimated, 52 minimum
Keith_Beddoe
Message 18 of 65
You are getting 56Mbs, which is above the minumum, and it may improve if you leave it alone.
They will not investigate if its above the minimum speed.
stoswald
Message 19 of 65
Yes, they are beliw
Keith_Beddoe
Message 20 of 65
Data rate:
You were quoted a minimum of  52Mbs, so you are within the estimated connection speed.
It may also improve if you leave it alone, no restarts or disconnections.
